Will I rub?
Old Aug 16, 2003 | 03:04 PM
anj2's Avatar
That's hot...
Will I rub?
After doing some research (via search), I'm pretty sure 18x8 with a 45mm offset and a 235/40/18 tire will not rub and fit fine.
Am I right? How bout with a conservative drop with Comptech? Just need some reassurance.
Thanks.
Old Aug 16, 2003 | 09:27 PM
dano80g's Avatar
I'm want to do the same. Here's what I've found,
Some have 225 40 18 on a 7.5 +48 rim and rub.
Cause; Too low, softer springs and/or struts, bad roads, agressive driving, heavy speaker box, Camber adjusted to zero degrees, tires(not all 235's are the same dimension and have different sidewall and shoulder shape).
Some have 235 40 18 on an 8.0 +42 rim and don't rub.
IMHO on these cars, the suspension doesn't allow the tire to travel high enough into the fender to rub. Also with a mild drop the wheel travels farther and the camber changes more tilting the top of the tire inward.
Bottom line. Too many variables. Best thing to do is find someone with a combo like yours that doesn't rub and do that.
Old Aug 16, 2003 | 09:37 PM
rondog's Avatar
Former Sponsor
you'll be fine.
Old Aug 17, 2003 | 11:00 AM
GOT PSI?'s Avatar
It's Go-Time.
Whuch wheel u getting?
Old Aug 17, 2003 | 11:21 AM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
18x7.5 +45 235/40/18 does not rub, Not lowered.
Old Aug 17, 2003 | 12:10 PM
Titand19's Avatar
East Coast Boost.!
just roll that shit
Old Aug 17, 2003 | 12:14 PM
mattg's Avatar
you may rub in the right rear.
Originally posted by Titand19
just roll that shit
Old Aug 17, 2003 | 06:29 PM
Hobes's Avatar
along the same lines...i have 225/40/18 on 18" 5zigen Heidfeld Mesh rims in hyber black (48 offset)...will i rub if i switched to 235/40/18? Thanks,
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Tribalheads
Sep 29, 2015 03:24 PM
