Will a dash with Nav fit an 01 CL without nav? Also, where to get dash.
Hey, I want to take an 01 CL that did not have a factory nav, put the dash from one that had a nav in it, and mount an lcd for an in car computer. Does anybody know if a dash with the nav cutout will fit in a car that originally did not have the nav? Will the dashes from TL's fit? Also, where could I find a dash?
Thanks for the input.
the dash nav trim pieces will fit from any 01-03 cl.
i would recommend one of the online acura dealerships, check and see which ones cheapest. they also pop up in the BM every once and awhile.
i'm not sure about the TL dash trim fitting.
search around and there are a few threads on the conversion but of course you could ignore the portion about installing the oem nav system.
Received 1,080 Likes
TL dash will not fit
The CL navi dash will require relocating the AC controls. The navi controls the ac but on non-navi cars you have the center section with the control. Someone did it here but it requires some custom fabrication. They moved the ac controls down to where the cd holder was and molded it all together.
https://acurazine.com/forums/showthread.php?t=194105
SOLD: 03 SSM CLS Auto
I remember checking out those links but not quite being sure about the dash and where to get it. Looks like I'll have some work to do with the ac controls. I'll probably ditch the factory head unit and put them in there somewhere.
Thanks for the info. With any luck I'll be posting a thread about a carputer install eventually.
Might want to consider putting in a double din dash kit and not have to mess with the ac contols ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
https://acurazine.com/forums/showpos...2&postcount=32
https://acurazine.com/forums/showpos...&postcount=191
We have a vendor who has 'em here:
https://acurazine.com/forums/sponsored-sales-group-buys-10/double-din-dash-kits-tl-cl-358673/
mada51589
05-03-2022 08:54 PM
BoricuaTL
04-08-2016 01:08 PM
