will an aftermarket cat set off your check engine light?
Old May 16, 2001 | 08:26 PM
CLpower's Avatar
teh Senior Instigator
what do you do w/ the o2 sensor in your stock cat?
Old May 16, 2001 | 08:42 PM
so cal type s_RENAMED's Avatar
thinking of getting the random?
'01 cl-s blk/blk :: comptech headers, comptech springs, comptech sway bars
Old May 16, 2001 | 09:31 PM
F=ma_RENAMED's Avatar
Want a test pipe? I've got one
10 ohm resistor to the front O2 sensor, and just tie off the 2nd one. Walla.
For real though, High flow cat's havent set off 2nd Gen 3.2 TL's check engine.
Kenny
Slow TL
Old May 16, 2001 | 10:37 PM
CLpower's Avatar
<font face="Verdana, Arial" size="2">Originally posted by F=ma:
</font>
hell ya i'll take your test pipe
Old May 16, 2001 | 10:38 PM
CLpower's Avatar
<font face="Verdana, Arial" size="2">Originally posted by so cal type s:
</font>
thinkin about it, know where i can get it cheap?
Old May 17, 2001 | 12:46 AM
scalbert's Avatar
</font>
This doesn't really make that much sense. The O2 sensor is a voltage generator. This low of an impedance on the circuit would certainly draw the signal down to near 0.
This is the primary reason why you can't measure the O2 sensor voltage with a basic analog meter. It requires a DMM with 10M Ohm or higher.
I have seen 'boxes' that can take the HO2S1 signal and slow its switching rate and level and then output it to the PCM input for the HO2S2. This tricks the PCM in thinking that the catalyst is fine and the sensor is intact. But I was under the assumption that Honda had recently gone to a wider band O2 sensors, closer to a Lambda 1...
Old May 17, 2001 | 12:48 AM
scalbert's Avatar
But back to the original question. There is no definite answer as to if an aftermarket cat will set a DTC. It could but may not.
If the 2nd O2 sensor (HO2S2) is still in line after the cat you would probably be fine.
Feb 25, 2020 09:57 AM
NJALLDAY57
Oct 13, 2015 08:25 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
trinikidcl
Sep 4, 2015 12:56 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
