Will a 3rd gen TL Rotora BBK fit a 03 CL-S? What mods needed?
Old 12-30-2006 | 12:56 PM
4ank's Avatar
I may buy a BBK from a 3rd gen TL, but want to make sure it will fit my 03 CL-S 6SPD.
These are the questions I have:
Are the mounting brackets the same? If not, what is required?
Are the SS brake lines the same? I am 98% sure they are not.
Will I need spacers with stock CL-S wheels? My guess is yes, but how many mm? Also, what about if I put TSX wheels on?
What else should I know before purchasing?
Old 12-30-2006 | 01:03 PM
jproy's Avatar
MP90 uninstalled
I have the Rotora BBK. If you take pics I will be happy to compare. I dont know about the bracket but I do have 2005 TL wheels on my CLS and you will need at least a 5mm spacer for the caliper/wheel clearance on the OEM wheel. Excelerate has them for about 70 a pair. PM him He knows all about these kits. What else should you know, They Fing rock! I find myself stoping four car lengs earlier than I normaly would have. The cool factor is through the roof. Standing on the brakes in the CLS at any speed is now a thrill ride. WOW! Can you tell I just got mine on? Jim
Old 12-30-2006 | 04:29 PM
Excelerate's Avatar
Former Sponsor
The difference is the SS lines. Everything else is the same. You will require a 5mm spacer in order for the stock CL wheels to clear.
Old 12-30-2006 | 05:57 PM
rondog's Avatar
Former Sponsor
lines, i had the same issue, swapped the lines and its fine.
handsom-hustla
11-13-2015 06:04 PM
nuldabz
09-03-2015 06:49 PM
cruisingnycfl
09-02-2015 01:11 PM
Nicho863
09-02-2015 09:12 AM
