Who wants cam gears?
#42
I will collect the funds and handle part assembly and modifications on the OEM gears.
Based on the immediate response I think I will try any get a group of 15 or 20. That will drop the price of materials a bit.
#44
I'm going to sit down with a CAD guy tomorrow and get some details worked out.
Since this forum won't let me keep an editable list of buyers I have the tally going over on J32a.com (http://www.j32a.com/showthread.php?t=1446)
Looks like this right now:
1. Me (J32A2 Auto)
2. HickamHatch
3. TLdream (J35A8)
4. TLdream
5. Nutnut
6. Rajca
7. richardparker
8. civicdrivr
9. Acidbath124
10. Virus
11. Jswapsedan
12. JCharged
13.
14.
15.
1. Me (J32A2 Auto)
2. HickamHatch
3. TLdream (J35A8)
4. TLdream
5. Nutnut
6. Rajca
7. richardparker
8. civicdrivr
9. Acidbath124
10. Virus
11. Jswapsedan
12. JCharged
13.
14.
15.
#48
One of them is advanced 3.5* to account for the width of the trigger tooth. The event that triggers the VR sensors is actually the end of the tooth, and since the teeth are on center with the spokes, to make the timing correct the keyway is advanced 3.5*.
Technical drawings are 90% finished. All I need to do now is get the keyway added in and then measure and implement the difference in relationship of keyway between the two gears. Instead of bothering to make the centers for each gear unique, I'll just introduce the variation with the reluctor wheel mounting points on the center.
Instead of using tiny screws I've decided to use tiny dowels, and to make their positioning non-symetrical to ensure that the reluctor wheel is mounted with the correct orientation in relation to the keyway.
#49
B A N N E D
and i also be down for a set, if i can get the funds together
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
also i posted in the other forum about a counter balanced trigger wheel
but one more thing i would also like to see is, some type of reference marks for adjusting them at least on one of the slots on each gear (especially for reference if they have slipped)
#51
Timing marks are definitely going to be there. A friend of mine will do the machining on those to keep cost down. They will be marked by .5* camshaft degrees and they will be on the far outer rim of the center piece, referencing the original tdc marks.
#52
B A N N E D
Did you see my response over there about the balance? I added the inner portion of the spokes to help balance it. I'm not too worried about the .53"x.1"x.125" pieces of mild steel: they'll only weigh .48 grams each. Whereas the out of balance portion of the OE pulley is at least 8 grams out of balance, and at a single point; not distributed across 180*.
as far as the reference marks; i was not expecting anything to be exact, but more just for reference, but having them exact would be good too
![Teef](https://acurazine.com/forums/images/smilies/teef.gif)
#53
Unless I can get my brain properly wrapped around the concept of a vernier scale and implement it on the center, it looks like we will be limited to 1* cam angle marks. Doing them at .5* spacing is simply to close together for the margin of error on the CNC router.
A couple hundred dollars out of my own pocket and I will be ready to test a trigger wheel prototype in a few days.
-Prototype trigger wheel will be in the mail to me tomorrow.
-OE pulley is in a local machine shop right now being face-milled.
-Cap screws, dowel pins, and a thread tap are in the mail.
-Mock-up prototype of the aluminum center (in wax or mdf) is in the works.
The test piece is going to simply be an OEM pulley with the trigger teeth ground off and a seperate reluctor wheel; the goal is to verify the functionality of the external reluctor wheel. Once that is done an everything checks out, we'll start talking details of group buy guys!
The things we are going to have to work out that I can think of at the moment are:
1. 6061 or 7075 Aluminum? I think the 6061 version could be done for ~$180 per set, and the 7075 for ~$220.
2. Where are we going to source all of the donor cam gears? They're only $35 each from Honda, but the prices above assume we figure out a way to get them a bit cheaper than that.
#54
3.7L Nitrous Breathing CL
Will these be able to be taken apart after assembled ?
So that we might be able to paint or anodize the gear part so that we could make it look nice like the center section will.
Also witch aluminum is lighter ? Is lighter the beter with this or is durability best in your opinon ?
With the cheaper aluminum will the screws be more likely to get stripped?
#55
B A N N E D
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
what would the weight difference be between the two? or would it be increased strength? (as parker kinda said, i want to MAKE SURE the screws NEVER strip)
i would say wholesale at the local dealer (considering you are buying multiples of the same thing, i think they be willing to though); but it looks like that might be the case already though
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
also considering that the fact that my car will be down for a couple of months
maybe do two batches of gears; first batch gets new gears, which then send in there old ones; then the second batch people get those modified gears, and the cost is split or so (or something along those lines to help cut costs)
#56
Q: Will these be able to be taken apart after assembled ?
with the marks being too close for the margin of error.
A: Definitely.
Q: .....so that we might be able to paint or anodize the gear part, so that we could make it look nice like the center section will.A: I'm going to glass bead both the new aluminum centers and the original steel gear. My thought is to simply clearcoat both of them once they are cleaned up nicely. I may paint the rim of the gear to make it look better, probably black, but not the teeth since that will rub off.
Q: Which aluminum is lighter ?The weight difference is negligible:
7075 Aluminum weighs 0.102lb/cu in
6061 Aluminum weighs 0.098lb/cu in
So, the former would weigh 5.6 ounces and the latter 5.3 ounces.
Q: With the cheaper aluminum will the screws be more likely to get stripped?7075 Aluminum weighs 0.102lb/cu in
The screws aren't actually threading into the aluminum. The tapped threads will be in the hardened steel outer ring. The aluminum will sandwich between it and the flange on the cap screw.
Q: ![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
With the marks being placed on the outer portion of the aluminum center, that's on a 2" radius, the spacing is very close even for single degree marks. To just do 1* instead of 0.5*, 10 marks would have to be made in a 0.33" length; that's marks spaced @ 30/1000th of an inch apart; and that's center to center; doesn't even account for the width of the mark itself.
Two main options here:
1. We can go with the 1* spaced degree marks and simply reference the original tdc mark for alignment.
2. We can implement a vernier scale which will require engraving markings on both the new center and the original outer ring but will give twice the resolution.
Q: What is the strength difference between the two metals?Two main options here:
6061/7075 in all cases:
Hardness (Brinnel) 95/150
Yield Strength (Ksi) 40/73
Shear Strength (Ksi) 30/48
Tensile Strength (Ksi) 45/83
Moral of the story; 7075 is much stronger.
Q: Maybe do two batches of gears; first batch gets new gears, those buyers then send in their old ones; then the second batch buyers get those modified gears, and the cost is split or so (or something along those lines to help cut costs)Hardness (Brinnel) 95/150
I thought about that possibility. We have to take into account tooling time having these machined down to the needed specs. I think that it will cost ~$35 per gear to have them lathed and have the holes for the threads milled if we do the full batch all at once. Not sure what price would be for, say, 5 sets, but I do know that the price to cut just one set would be much higher: ~$75. So figure there is some sort of median there that we would settle for in that case.
#58
Thanks for the offer, but I have three sets sitting around here.
EDIT: haha @ wtf are you thinking.
There are still two things I have to sort out; keyway and trigger relationship to keyway. I picked up an degree wheel to try and figure some things out, but I'm not happy with the resolution. I'll probably end up using my DSLR to take a very high res image from a perfect Z axis and then break the picture down in a vector editor to figure out exactly what's going on there.
#60
I think there are probably quite a few people who are interested but unable/unwilling to put money up front. To that end, I think I am going to end up financing additional gears out of my own pocket and selling them afterword.
I'll have quite an investment of time and resources in this project when it's all said and done, and I think it will be fair for me to at least recoup the value of my time.
Keep in mind though, these will be marked up to some extent over the group-buy price and I won't be able to discuss them in this forum since I am not a vendor.
#64
^ you have the ability to adjust cam timming .advance/retard
Retard for more top end power,but will lose a little low end.Good for charged,boosted,nitrous
Advance for low end power,but will lose a little top end.Good for n/a
I could be wrong but,these are the flexibility reasons I want them.
#65
I'm actually scheming, at this very moment, to implement a feature on these that will actually yield Hp gains (not just move the powerband up or down the rpm range) on cars running factory electronics. More on that later.
The OE pulley has been face milled down 1/8" to make room for the 1/8" thick reluctor wheel:
![](https://lh3.googleusercontent.com/_Zxi5uBiDYZQ/TW6lStLS20I/AAAAAAAA99c/VE_IN6nt5Ew/IMG_0964.JPG)
and....... I went ahead and had one of the gears prepped for the non-existent prototype center hub which I will try to bring into existence in the next week or so; I'm tempted to have it done in the finish material (aluminum) but that will be quite pricey; $250 at least for a pair. More than likely, I will use the prototype trigger wheel to verify the sensor functionality, do a cutout of the center hub in wax just to make sure there aren't any dimensional problems, and then get ready to order the whole lot at once.
Anyway; picture:
Anyway; picture:
#66
B A N N E D
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
so gotta get a little cash flow before i can put some money out
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
and as far as ordering them all in one lot, very possible but as you said, you would at least do a wax one and such for dimension checks and such
#67
wham bam thank you ma'am
i have bills and tickits to pay right now
, so yeah money is tight right now (let alone waiting [pre-ordered] on excellerate's mounts
some, but more of a benefit for the modded cars though, and as parker said VVV i want them more for the adjustability factor of them, and being able to shift the power pand around some, to my likeing
(not toatally sure on the directions, but i have not looked into it recently; i think it may actually be reversed from what you are saying though
at first i was think the reluctoir wheel was going to just bolt to the new center and stay attached to that, but i guess sandwitching it too would work (maybe put locktite on the cam bolt, to make sure it doe s not come undone unexpectedly, but that should be about it though)
same here. its a bitch
#68
B A N N E D
also on this....
are you ABSOLUTELY sure the magnetic field will be created at the some point on the new reluctor as it does on the stock ones, since they are tapered, and may make that magnetic field at a ever so slightly sooner point (and collapse at a slightly later time) due to the sloped part of the pickups, and putting that much more "mass" outside of where the machined flats are
about the only way i could see verifying that is putting them both on an oscilloscope and making sure the pattern rises and falls at the same time (and is the same width/number of degrees of "on" time)(maybe referenced to the crankshaft too)
(edit: i was thinking of mounting them on a common shaft, then measuring them, but you then introduce the variability of different sensors then, so maybe not)
also remember different distances from the sensors, can also vary the on and off times slight too, as one more thing to consider
"sorry" for asking the headache type of questions, just wanna make sure these will work absolutely no different then stock even in the smallest of details
#71
I'm not sure. That's the reason for testing a prototype first. Also, I'm going to have a conversation with someone tomorrow who I think will have a good answer. If need be I will test rig both on an oscilloscope for testing. Worst case scenario; price jumps due to necessity of different machining process for more complicated reluctor wheel
design.
design.
#72
B A N N E D
design.
design.
#73
OK, good-ish news. This chart shows "typical" Variable Reluctance Sensor Output versus Air Gap:
![](https://lh6.googleusercontent.com/_Zxi5uBiDYZQ/TW8f01N_zQI/AAAAAAAA9-c/890I9YXYF7M/SensorOutput.JPG)
And, .050" down on the tooth looks like this:
![](https://lh3.googleusercontent.com/_Zxi5uBiDYZQ/TW8f01bMcpI/AAAAAAAA9-Y/rDy8yxVlAwo/IMG_0970.JPG)
So, if these aren't putting out what they need to, I can simply go wider (that point is .15" instead of the .1" I had prototyped) on the teeth and set up an angle grinding jig to duplicate the slope.
I also found out the manufacturer for the sensors and will contact them tomorrow for a technical data sheet.
#74
I see what you meant now; the keyway tapers into the camshaft so the point at which this mounts is totally circular. There is no keyway to use.
#75
A few items for the gears showed up today:
The flange socket head cap screws; these are class 12.9.... the minimum tensile strength on them is 176,900 psi. No, that is not a typo.
![](https://lh4.googleusercontent.com/_Zxi5uBiDYZQ/TXB4DugB_BI/AAAAAAAA9_c/3k9QRUBjnU8/IMG_0978.JPG)
And then the dowel pins that will keep the reluctor wheel properly aligned with the pulley. These are 18-8 stainless steel. Yes, that's the tip of a ball-point pen.
![](https://lh5.googleusercontent.com/_Zxi5uBiDYZQ/TXB4DubuUJI/AAAAAAAA9_g/Krh5ZCI65q0/IMG_0979.JPG)
And just for good measure; I went ahead and tapped the threads for the cap screws into the OE pulley:
#77
B A N N E D
![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
and
also as far a material choice with the center section of 6061 or 7075, i could really care less, since the weight difference is so minimal, hard to justify $40 for 0.3 ounces; but would be helpful to achieve the LAST bit of performance though
#78
and
#79
B A N N E D
also in this picture i see one thing (but considering it is just the prototype though, no worries)(might also just be the photo though) the top left bolt seems to be sticking over the edge a little compared to the others
also i would like to see, if possible, for the outer ring to actually be "hub centric" to the new inner section, so that it the gear itself/belt surface run perfectly true each and every time it is adjusted, and don't have any runout (so the timing stays exact; and the tensioner will not have to compensate for it AT all)(and the bolts only have to squeeze the two pieces together, and not carry any additional loads then needed)
ie: think about aftermarket rims that are not "hub centric"
#80
The tolerance to which the holes will be tapped into the OE gear will be .002" of an inch. The clearance for the through hole slots in the aluminum will be .004".
I think I understand your point though and agree that it would be the correct design.
