Who makes the electrical connectors for our cars?
What company makes the electrical connectors for our car. I need a male and female connector for something, and haven't been able to find them sepretly, without buying a ton of stuff I don't need. Anyone have any ides what company makes them? Does Honda make them?, or do they farm them out?
Anyone have any ideas where I can buy them individually?
what connector ?
https://acurazine.com/forums/ramblings-12/anyone-work-honda-manufacturer-not-dealer-know-someone-who-does-303315/
was about the wiring harness, but you might want to ask one of the A/V forum guys (like Jonesi)...
what connector ?
Originally Posted by allmotor_2000
AMP, a division of TYCO
Unfortunateley you have to buy in the 100's or 1000's quantity!
Often they'll send "one time samples" in much lower quantities though... at least that's what I was told.
Thanks. Do you know which ones you were looking at? May be similar to what I need.
everyone is asking you... WHAT connectors DO YOU NEED?...
answer the question fruit cake.
I'll just say its one none of you here have on your car, well steve for a little while.
I'll take a picture later, but its a gray rectangle with 6 pins on the bottom, and 4 on the top, 2 on the left, 2 on the right, and 2 empty spaces in the middle. It'll be easier to see with a picture.
my car goes put put put... and burr burr burr when I open up the top and try to fill up the turn signal fluid...
what is wrong with it?... oh hell, someone help me!....
Originally Posted by mrsteve
The UniShit?
shhhhh he does not want anyone to know he owns that garbage....
spies... spies I tell you.. spies everywhere..
Originally Posted by NSXNEXT
Is it the connector to plug in your inflatable girlfriend?
Fine, its one for the tranny (Get, all of you have 6 speeds, Stevo is getting one, bleh it was a bad hint). I'll snap a pic later though to show you the exact one. Its part of the wire harness for the inside of the car, so its not like acuraautomotiveparts.org has it seperate.
What do you need it for Brett?
http://imageevent.com/mclarenf3387/a.../connector?n=0
Sorry, the pics kinda suck, but you get the idea. Does it look like one of the ones you needed Ram? I can't seem to find a connector like it on AMPs website.
Old&CnL
I work for Tyco Electronics Automotive North America- not all the connectors are Tyco- some are Molex, some are Yazaki, FCI, and even a few Foxconn's. Price rules in Automotive supply. Sounds like you may have a hybrid, perhaps a Multilock style. Is it sealed??
Many of the Honda connectors are from Tyco Japan, and aren't stocked here. Send a picture, I'll check around. Keep in mind the terminals come in a reel, and require special crimping, etc.
Are you replacing one or modifying something??
I plan on making a harness that can be removed later on. I can easily complete the project without it, but I would rather not have to splice into the stock wires directly.
The pics are in the link, but if you need a better one, I can get another one later. If you can find out anything about the exact manafacturer or part # it would be greatly apreciated.
going to be a while before you get a straight answer out of him...
Old&CnL
The connector is not a Tyco Electronics connector. Our guess is JST, JAE, or Summitomo origin, using a hinged secondary lock. It's not hybrid but has all the same terminal sizes, most likely a 1.5mm box and blade. Definitely Asian manufacture. May be difficult to locate here w/o buying the cable assembly from Honda or pulling it from a parts car. You can see it is selectively keyed for the application.
Hope this helps.
Hope this helps.
Former Sponsor
well, if it's a connector, why nore buy the other end of whatever it connects to and splice it to a fresh wire. then again, I have no idea what the wire consists of, but that would be a good way to rig it. try radioshack, or even do a search on google, i'm sure there are companies out there who will provide you with something.
Hope this helps.
Hope this helps.
Can anyone get the plug from dash harness that goes into the ECU of a 6MT CL-S. Let me know soon, my email is andauto@yahoo.com also send price. Looking for at least one but no more than 20.
Thanx,
Tony
Thanx,
Tony
Hope this helps.
Hope this helps.
Thanx,
Tony
Thanx,
Tony
Shhh, you
COntact scalabert. He can probably pint you in the right direction for those connectors since he made the PnP E-manage harnesses for the 6 speeds.
you giving away my advise to you to other people and you want me to keep tight lipped about your project.... the teacher is going to break out the paddle and give you a beatin!
Is he trying to make the Radio controls on the steering wheel operate the auto like this guy ??
https://acurazine.com/forums/showthread.php?t=170332
Originally Posted by GreenMonster
So what's the deal ??
Its not possible since the radio buttons are wired to a pc board. Its not like they are simple switches with two wires coming out of them.
cak165
1G TSX Problems & Fixes
09-02-2015 09:21 AM
