Where is our WHEEL HOP CURE??
Who was working on the Wheel hop problem...???
ChadT?
Did we make any ground on the fabrication of this MOD???
ChadT?
The last thing I did was fill the radius rod bushings with urethane. It helped a bit. I then sandwiched a couple of washers between the bushings and this helped some more. There has been some improvement with the wheel hop but I can still make it hop if I pop the clutch with a lot of revs. It is a lot easier to launch though and I don't notice the wheel hop so much. I'm not surprised by it like before. It's much more tolerable. I wouldn't say it's totally cured though. The next thing to do would be some sort of brace that solidly locates the lower arm. I have also seen a solid ball joint for older CRXs that can replace the radius rod bushings with a solid connection. This might be worth a try. One side benefit is that the front really grabs going into a corner. I can't really get the stock tires to squeal around a corner any more. I really need to compare it to a car with stock suspension to tell how much improvement there really is. It's enough that I'm not that much bothered by the hop anymore. That may change when I put the summer tires back on. I also filled the motor mounts with urethane which also firmed things up.
__________________
Chad T
__________________
Chad T
W T F ?
hey Mike, while you're at it you may want to clean up pg. 21 in the unichip possibilities thread.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
link me
Spectacular Aroma About
Originally posted by proaudio22
Have any of you thought about having solid mounts machined?
I would like to try these radius rod bearings for the radius rod bushings.
-S namyaC-
Originally posted by ChadT
You mean motor mounts? Solid would be pretty rough. Filling the stock mounts makes them much stiffer but leaves them fairly compliant.
Yep. I friend of mine swapped his out for solids in his GTI, a lil rougher but not bad. He says the benifits are worth it. It's the hardcore option if you really want the performance.
I drove in a solid 1.8T GTI and it was miserable bro, the car shook so bad on the roll out
Adventurist.
-S namyaC-
I dunno if it matters, but his 89 is just sporting the 2.0 16v. This is his project "toy" car (in addition to his daily driver MR2-T and his 240sx) so he doesn't have to deal with it all the time either.
You sure the shaking wasn't something else?
Adventurist.
-S namyaC-
If it wasn't my daily driver, I'd have some solids machined. I have access to a machine shop, but I'd just have some contacts to it. I doubt many peeps here would be in for a solid mount.
PS: the comment about something else was directed at CLpower, you snuck your post in there before me. ;D
Originally posted by Smitty
Jens had the solution but ChadT never followed through...
and someone else was working on a BRACE.... who was it?
Originally posted by Akim711
can someone define wheel hop for me real quick?
Originally posted by NiteQwill
I don't see why no company has made mounts for our cars, especially with the amount of power transfered to the wheels.
A senior member
For front wheel drive cars, unfortunately, wheel hop is very much an inherent problem due to the tremendous weight transfer to the rear wheels when you come out of the hole. You can reduce some hop by mod or go easy on the pedal initially.
JByron
01-08-2016 09:49 PM
