Where to get fenders rolled in MD/DC/VA?
MP90 uninstalled
find out EXACTLY where it is rubbing first. May not be the part of the fender you would roll. I have a drop with 8" wide wheels with 235 tires and it was rubbing where the bumper meets the metal part of the fender well. I ground it down a little and all is well.
Don't Mess With Texas
dammn OG member from 01.
like jproy said, see if you can see where its rubbing at. if it is rubbing that tab he is talking about where there is a screw with a large washer then the roller will do you no good.
just get a dremel with a cutting wheel and grind it down as much as you can.
MP90 uninstalled
Originally Posted by TOPHER33884
you will cut into your tire...I learned the hard way!
So did I my friend....so did I! Its interesting because the passenger rear doesnt hit it if the wheel is completely compressed through the suspension travel. Just goes to show you the manufacturing variances.
MP90 uninstalled
This shows the location we are talking about
You can see the green arrows show where the metal is you need to trim and the purple shows where to trim the platic down a little if it is rubbing. You can see where it was rubbing on my tire and where the tire rubbed down the plastic quite a bit from friction.
This shows the finished trimmed area. It doesnt rub anymore
MP90 uninstalled
My rear tires were pretty much lined up right under the metal fender so even the slightest bumps caused me to rub. I had the fenders rolled at a place in Wheaton for like $150 and it hardly ever rubs anymore unless you drive into a huge pothole or something.
DerrickW
11-15-2015 05:52 PM
09-25-2015 06:14 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
