When do you change IK22 spark plugs on S/C6spd?
What to do, what to think
I have about 6k miles on my blower over 1 1/5 years now since install plus I drive aggressively . How often do you S/C guys change the spark plugs (IK22)? I"m thinking about changing them, the battery 51R (cheap energizer) and the front 6spd engine torque dampener that jproy introduced as well as the rear one also, since I'm removing the blower might as well do everything at once.....Mr Steve, Allout can you guys chime in
I had my supercharger installed at around 51K, and I now have 60K on the car. I intend to change my plugs at 105K based upon the Acura service interval. I will have the blower serviced at the time as well.
But I don't drive all that aggressive very often.
Your using Denso IK22's right?
I just need to change my plugs tomorrow period before i go to the track. I got 91k. I was also thinking about getting my first mobile 1 syn oil change. I want my car running right tomorrow night at the track after i get the headers and crank pulley on.
I run regular oil... I will switch to synthetic soon.
Originally Posted by mrsteve
6k miles on a set of plugs is nothing.
when do you think I should change them? another 90k miles? I have 54kmiles on the CL now
Blown is Best
Blown is Best
4drs just wanna have fun!
Originally Posted by krisdlm
The ik22 stock number is #5310. I have to order another set for the cl b/c mine fouled up. They're the ones off an rsx-s right?
I would think 60K max for the Denso plugs. talked to someone at Denso about this a while back, plus they only have Iridium on the electorde and the ground has ordinary Nickel coating so it won't reist erosion as much as platinium and Iridium. I think Bosch has some double Iridium plugs but if you want them to last you long just get something that has a Iridium electrode and either iridium or platinium for the ground.
But I would replace them around 50K or at least just check them from time to time and do it sooner if necessary.
