Wheel question...
Old Jun 30, 2002 | 12:11 PM
Jeff914's Avatar
TYPE WHOA
Wheel question...
What is the spacing? how many lugs? what is the offset? any other info I need to find rims which will fit on the 2003 CL type-s. Thanks
Old Jun 30, 2002 | 05:07 PM
Edub-TL's Avatar
Sticky Rice OwnZ joO
The stock offset is +55, the closer to this the better.
Minimun of +45 is recommended. But this can be flexible, depending on how wide your wheels are.. don't get one too low, otherwise you may have wheels that stick out too far..
Bolt pattern is 5x114.3 aka 5x4.5
Not sure what you mean by spacing.. I'm assuming clearence..
if you're not lowered or planning to lower, you can get just about any wheel you want... but you more than likely won't be able to get anything larger than 19x8 and nothing smaller than 16x6.5..
As for tires.. that's another story.. decide on the wheel you want first (diameter, width, offset), then you can choose the tire..
Old Jun 30, 2002 | 07:11 PM
Chief F1 Fan's Avatar
Might I offer a simple suggestion here please?? This is a HUGE area of talk on the board, so do a search and you 'll see that which you seek. Second, look at the sigs, go to the following for prices (for a start)
www.wheelmax.com
www.tirerack.com
www.discounttire.com
www.precisioninstallations.com
valleytire.com
That'll get ya started. Tirerack has an interactive program that allows you to see what fits on your car in the color of your vehicle as well.
Feb 25, 2020 09:57 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
JByron
Jan 8, 2016 09:49 PM
GhostTL09
Sep 19, 2015 01:57 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
