wheel alignment
wheel alignment
How offten should I do it? The last time it was done 1 year ago, but now I put new tires.... The car rides perfectly straight on the highway, seems like a waste to get it done?
Another question, how offten do you guy re-balance your tires?
I only did it when I had suspension work done. Take it to one of those places that gives a lifetime warranty on alignment. That's my plan for the next time I have to get it done.
Originally Posted by lokijibber
change tire size or suspension = alignment
as for balancing. i rotate every two oil chgs (7k) and balance the two going to the front then.
Originally Posted by phipark
Don't fix it, if it isn't broke. If you want, just have someone check you alignment and see if you need it done. The dealer checked mine and said it was ok at 30k.
get an alignment check. usually free to do.... some charge like 30 bucks. its worth it to know.
hmn, never heard about "alignment check", they either offer to do it or not.
I agree that frequent alignement is a good thing, but on the other hand you could hit a pot hole and your alignment will be off... I am doing each 1-2 years... or if I see a problem.
Zonian22
Nov 14, 2015 01:20 PM
Zonian22
Sep 2, 2015 08:19 AM
