what would i need with a SC?
Old Jul 22, 2001 | 08:02 AM
mr5parkle's Avatar
what would i need with a SC? like you know how turbo's need blow-off valves, intercoolers, wastegates, etc. what would a SC need? would i need to replace the tranny? buy other stuff?
Old Jul 22, 2001 | 01:12 PM
KCPreki11's Avatar
Originally posted by mr5parkle:
<STRONG>what would i need with a SC? like you know how turbo's need blow-off valves, intercoolers, wastegates, etc. what would a SC need? would i need to replace the tranny? buy other stuff? </STRONG>
Intercooler, Tranny, Level 10 TC wouldnt hurt. I thought wastegate and blow off valves were just for Turbos. But i think i might be wrong
Old Jul 22, 2001 | 07:27 PM
Achance's Avatar
Coming to a city near you
J&S safeguard unit to help control detonation.
Old Jul 22, 2001 | 07:47 PM
jdl75's Avatar
Retard ignition 1-2 degrees depending on flow increase. You may require higher octane, but not likely.
The SC will provide added low end grunt, which the tranny can handle. The SC will serve to increase torque some, but more importantly, it will move it down in the rev range. The tranny doesn't much care where in the rev range the torque is produced - just how much.
Old Jul 22, 2001 | 08:59 PM
z28typeSWRXkid's Avatar
a car that has a supercharger available....try a prelude
Old Jul 22, 2001 | 09:41 PM
FDao's Avatar
A typical SC package would consist of the necessary pipings/tubings custom made for that particular car. Depending on how much PSI you want, this also may necessitate larger fuel injectors, ignition system for better sparks and timing retardation for detonation prevention, ECU upgrade, and intercooler, along with a smaller pulley. Most packaged SC will only run 3-5 PSI,thus making the above mentioned equipments unnecesary.
In summary, a simple mild SC package would consist of the necessary pipings/tubings and an SC with the appropriate pulley/belts. You will also benefit from adding a CAI intake, headers, and exhaust to fully maximize the available boost. An upgraded ignition system may be beneficial but not necessary when running low boost.
Old Jul 23, 2001 | 02:03 AM
ACuraR's Avatar
A warranty...
Old Jul 23, 2001 | 01:45 PM
MCHM3's Avatar
magnet
on our cars a 6sp tranny
Old Jul 23, 2001 | 03:00 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Originally posted by FDao:
<STRONG>
In summary, a simple mild SC package would consist of the necessary pipings/tubings and an SC with the appropriate pulley/belts. You will also benefit from adding a CAI intake, headers, and exhaust to fully maximize the available boost. An upgraded ignition system may be beneficial but not necessary when running low boost.</STRONG>
I agree...however, if you plan on launching your CL with that much torque...I would plan on adding billet CV axles...as stock Honda CV axles don't like gobs of torque off the line...
Old Jul 23, 2001 | 03:25 PM
KCPreki11's Avatar
<STRONG>
So you and JDL75 dont think we need a tranny? Then what has all this fuss been on the board been about needing a new tranny and peoples trannys breaking down just on normal use, and not that many miles on it?
