What is Understeer?
Old Feb 14, 2001 | 03:46 PM
Acura_CL
Guest
Posts: n/a
What is Understeer?
What is Understeer? I looked it up but all it says is tu turn less than the driver expected. That sounds like a non-answer. Can't one correct for understeer simply by turing the wheel more? What about oversteer?
Red 3.2 CL-S.
Old Feb 14, 2001 | 04:48 PM
MikeS 18's Avatar
Adult Supervision
My view on understeer is when the car does not react to the turning which you are doing with the wheel. The tires begin to slip forward and not turn the car as much as you want. You begin to plow through the turn.
Oversteer is just the opposite. The car seems to grab too tightly and turn into the turn more that what you expect from the amount of steering wheel turn that you have made.
CL-S #22,299 Black/Parchment/Nav, spoiler, door & fender guards, wood trim, PIAA 19169 & 9005, V1 w/remote, trunk & winter mats, no headers, no sway bars, no springs, no money!
Old Feb 14, 2001 | 06:00 PM
Achance's Avatar
Coming to a city near you
When you are trying to go around a turn fast, and you can't hold it and end up in the other on coming traffic lane. That is understeer, you want a car to have a little bit of oversteer.
Old Feb 14, 2001 | 08:11 PM
DtEW's Avatar
Famous quote from a famous rally racer that doesn't immediately come to mind:
"Oversteer is when the navigator is really scared. Understeer is when the driver is really scared."
051/LP/SR/LD/HH
Old Feb 14, 2001 | 10:50 PM
soopa's Avatar
The Creator
This is a first... moving from O/T to Car Talk ...
2001 Acura 3.2 CL Type-S
San Marino Red (Navigation)
PIAA 19173 Ion Yellow Fog Lights
Aftermarket Black Wood Trim Kit
Old Feb 15, 2001 | 03:30 AM
Water Rabbit's Avatar
Wow only on my 2nd tranny
Understeer: You are going around a corner and as you turn the wheel the car wants to keep going straight.
To correct this, ease up on the throttle and apply a little brake force. This has the effect of making the front of the car dive, and transfering more weight onto front tires so they grip more, and you can steer better.
Oversteer: You're going around a corner and the the car's rear tires break loose making the tail of the car try to pass the front of the car on the outside.
To correct this, you want to make sure you turn the wheels toward the direction you are sliding and give the car a little gas. This will push the rear of the car down and transfer weight to the rear tires, making them grip better and straightening out the car again.
The common denominator to correcting both problems is weight transfer.
Two keys to correcting oversteer and understeer:
1. ALWAYS look where you want to go, not at what you're worried about crashing into. Sounds easy - but takes practice. You have to have confidence that the car will go in the direction you are pointing your head.
2. Apply steering, throttle or brake changes gradually and smoothly; if you don't you will overcorrect and the car will take control away from you.
I am paraphrasing the above from a few days indoctrination at Bob Bondurant's School of High Performance Driving. If you ever get the opportunity to go there, you will leave with an unduplicatable understanding of understeer/oversteer . . . and a huge grin on your face.
[This message has been edited by Water Rabbit (edited 02-15-2001).]
Old Feb 15, 2001 | 06:38 AM
SoundSpeed's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Water Rabbit:
</font>
Good advice. Same thing applies if you start to slip in snow. If you start to skid in snow take your foot off of the accelerator and the brake and very, very gently turn into the skid until you car is corrected.
True Hip-hop junkie
Old Feb 15, 2001 | 09:13 AM
tel1sps's Avatar
Another quote from the racing world,
"Understeer will cause you to hit the wall with the front of the car. Oversteer and you hit the wall with the rear of the car".
01 Silver 3.2CLS
Old Feb 15, 2001 | 10:33 AM
MikeS 18's Avatar
Adult Supervision
</font>
Bob Bondurant aka Water Rabbit!
Old Feb 15, 2001 | 11:17 AM
<font face="Verdana, Arial" size="2">Originally posted by MikeS 18:
</font>
Wow, you nailed me.
Takes one to know one?
I was there earlier this month for a course, but I thought all this was a pretty general view of understeer/oversteer. If it's so easily identified as Bondurant's philosophy then I am remiss in not crediting my source. I'll fix that.
Old Feb 15, 2001 | 11:32 AM
NOVAwhiteTypeS's Avatar
Best way to learn is to go play some Gran Turismo
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Cargo Net/Acura Car Cover/Tint 20%,35%,5% on Sun Roof, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter. Comptech Springs. Polarg m-6.
Comptech Headers, Comptech Sways, Eurolite Xenon Crystal high beams.
AEM CAI once they decide to make the dame thing.
235/40/17's or 225/45/17's once I found out which one works for me.
gtech 0-60 6.03 w/ 438 pound load. preheader.
Old Feb 15, 2001 | 11:36 AM
Acura_CL
Guest
Posts: n/a
Hrm... I don't have a Playstation.
Red 3.2 CL-S.
Old Feb 15, 2001 | 12:41 PM
bone_stock's Avatar
You can tell you guys are cyber drivers and not real track drivers. If your car is understeering and you apply the brakes you understeer MORE! The only way to get out of an understeer situation is to let the car slow down naturally, add power (rear wheel drive only), lift throttle oversteer, down shift, or pull the emergency brake slide routine.
Old Feb 15, 2001 | 02:35 PM
Shawn S's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Acura_CL:
</font>
Ask “JARU”(sp) about this phenomenon.
He can provide actual pictures of what happens when things go horribly wrong.
aka...Wreck
Shawn S
Speed limits are for CARS and DRIVERS whose limits are easily exceeded !!!!!
2001 CL Type S - NAV - San Marino RED / Parchment - Spoiler - 35% Tint - Roof Visor - PIAA Lamps
GOLD Emblems & Grill - V1 w/remote - KICKER ZR-360 w/(2) 10" Alumapro Subs - Shine by ZAINO
For Pictures see: PAGE 1 PAGE 2 PAGE 3 PAGE 4 V1 & SUBS
Old Feb 15, 2001 | 02:49 PM
<font face="Verdana, Arial" size="2">Originally posted by bone_stock:
You can tell you guys are cyber drivers and not real track drivers. If your car is understeering and you apply the brakes you understeer MORE! The only way to get out of an understeer situation is to let the car slow down naturally, add power (rear wheel drive only), lift throttle oversteer, down shift, or pull the emergency brake slide routine. </font>
R.I.P.
Old Feb 15, 2001 | 03:36 PM
KavexTrax's Avatar
</font>
Dreamcast then? 99.99 everywhere now and days
I recommend Sega GT...BADAss game!
- Kvit -
2001 CL-P Monterey Blue, Parchment interior
Polarg BlHybrid M-6 Road lamps
http://albums.photopoint.com/j/Album...725&a=10358832
Club Events Moderator
Old Feb 15, 2001 | 06:27 PM
Acura_CL
Guest
Posts: n/a
I think it I just turn into the skid like drivers ed told me years ago, I'll be OK.
Red 3.2 CL-S.
TheMirror
Sep 17, 2007 08:44 AM
GreenMonster
Aug 22, 2005 07:32 AM
gavriil
Apr 29, 2005 11:30 AM
gavriil
Mar 15, 2005 06:14 AM
gavriil
Dec 17, 2003 08:28 PM
