What is "trap speed"?
Old 05-20-2002 | 04:30 AM
D73's Avatar
D73
Curiosity Killed The CL-S
Someone please educate me... What is "trap speed" and how does that affect how fast a car is? Thanks!
Old 05-20-2002 | 09:44 AM
Dom418's Avatar
I LOVE MY CAR
Well the trap speed is not your actually speed at the end of the 1/4 mile...
It is the Avg speed over the final portion of the run.... your actually speed at the very end of the run is always going to be a little higher than your trap speed...
I'm sure someone could elaborate on this further, but that's the basic ideal...
DOM
Old 05-20-2002 | 11:02 AM
Pull_T's Avatar
Trap Speed (both for 1/8 mile and 1/4 mile) is measured in a 66 foot speed trap that ends at the finish line (and/or 1/8 mile line). The trap speed therefore, is calculated as an average speed through these timing lights.
Trap speed is generally a better indicator of a car's performance capability than ET since even if a car is driven very poorly off the line resulting in a bad ET, the trap will generally always be where is should be. For example, if I have a good run in my Cobra, I might run a 13.3@105 mph. However, if I spin really badly off the line and/or miss a gear, my run might be 14.2@105. You could also normally assume that the car with a higher trap would win a race "from a roll"....
Old 05-20-2002 | 11:04 AM
Dom418's Avatar
I LOVE MY CAR
I was close....
DOM
EDIT - This was post 1K, kind of a waste
Old 05-20-2002 | 03:07 PM
Tom2's Avatar
Unregistered Member
Originally posted by Pull_T
.....However, if I spin really badly off the line and/or miss a gear, my run might be 14.2@105. .....
If you spin badly, most of the time you should actually have a HIGHER trap speed than you would if you hooked up perfectly.
Think about it- after spinning, you'd be going through the beams at a higher rpm than you would have otherwise.
I had a AWD Talon Tsi that would run 13.20's all day but only trap at 103. And that car NEVER spun
Old 05-20-2002 | 03:28 PM
Pull_T's Avatar
I know that man, I wasn't trying to get that specific in the explaination. I was just trying to demonstrate that there is a difference between running a 14.2 at say 105 then running 14.2 at 95. The car trapping higher is "faster" though the times are the same (if that makes sense)...
A run between your Talon and my car would be a good example of how different vehicles perform differently, we'd be pretty evenly matched in a quarter mile run, anything shorter you'd likely be ahead, anything longer and I'd likely be ahead...
Matter of fact, yesterday, the track hooked for shit and I actually pulled off a wonderful 14.3@108.5 (2.4 short time)...
Old 05-20-2002 | 03:34 PM
D73's Avatar
D73
Thanks folks! Now I think I get it.
Old 05-20-2002 | 04:01 PM
Mike's Avatar
so what was once a 12 second car w/a 13 second driver is now a 12 second car w/a 14 second driver?? :P
Old 05-20-2002 | 04:07 PM
Dom418's Avatar
I LOVE MY CAR
Noooo, wouldn't it be a 12 sec car, w/ a 13 sec driver, on a 14 sec track??? :P
DOM
Old 05-20-2002 | 04:10 PM
Pull_T's Avatar
Bwwahahahahahaaaa
oyayjoe
01-01-2019 10:17 PM
mrkingstonvi
02-22-2016 01:53 PM
09-25-2015 06:05 PM
oyayjoe
09-12-2015 04:40 PM
Quick Reply: What is "trap speed"?
