What size injectors?
3.5 psi
i don't think that's too much. I know NVA is putting RDX injectors (410cc?) in his s/c setups. Just from reading here, i think i remember that the S2K are a direct fit but more expensive. The RDX require a little work and are cheaper.
B A N N E D
for the best idle quality and such, i would keep the injector size to the minimum size needed, so just large enough, so it all depends on how much power you are planning to make
with the smallest injector that meets your requirement, the better control over the amount of fuel into the motor it will have, since like each millisecond (it's more precise actually, but more for ease of explaining), it injects a smaller amount of fuel, so it has smaller steps of how much fuel it actually wants to inject into the motor, which is especially critical at say like idle, where you do not have much airflow, so really small requirements of fuel
that is also why those twin injector setups (for each cylinder) excel so well in driveability (even say just adding two injectors to your motor, one for each bank, would help too for driveability, since you can make them deliver most off the fuel you actually need up in the higher rpm's and higher boost)
Whats up with RDX owners?
RDX injectors are cheaper then the S2ks. Get those and use a FIC or emanage to pull back the fuel trims.
B A N N E D
so basically you figure out the size you need, then go one size larger, so it has some reserve, but not a whole lot though
B A N N E D
btw diddy try this for injector sizing (i don't know exactly how accurate it is though, let alone needing some very specific numbers about your setup, that you might not know though)
anyways:
http://www.rceng.com/technical.aspx
anyways:
obviously you use a slightly larger injector then necessary, but you don't put say a 500cc injector, when you can get by with one at 450cc, and still have it meet all fuel requirements under ALL conditions
Id much rather run an injector and 75-85% peak then 95%.
wham bam thank you ma'am
$38
http://www.acuraautomotiveparts.org/...s=&view=normal
(number on picture)1 (part number)16450-RWC-A01 INJECTOR ASSY., FUEL (year)2008 RDX (list)50.95 (our price)38.21
![](http://www.acuraautomotiveparts.org/acura/jsp/mws/catimgs/14stk701_e0310.png)
$38
B A N N E D
and also with keeping the injector to a minimum, you also give the fuel more time to fully atomize into the air, so more power, but also better fuel economy in the process
cause too big of a injector is just like dumping a can of gas on a fire at once, where if you put it in a nice fine mist, it is alot more controlled burn, let alone being able to burn every last drop of the fuel available
Thats what tuning is for. You can pull back on the injectors if youre flowing too much fuel.
![](http://static.open.salon.com/files/duh-duh1233387823.jpg)
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Lol, hes not wrong, we (collectively) need to clarify our responses a bit better so it can benefit all that search for answers.
How much were the RC440s?
ExcelerateRep
10-14-2015 08:20 AM
AcuraKidd
09-25-2015 11:18 PM
