What kind of motor oil do u feed your cl or other vehicles
Old 10-21-2003, 06:53 AM
Powered By HONDA
Type S's Avatar
i always feed my cls with full syn Mobil 1 5W~30W motor oil
and my jeep just regular 10W~40W oil...
and what i found weired is..
my element only requires 5W~20W motor oil..
why???cause the engine is not produce much heat or friction?
it is same as civic DOHC VTEC 2.4 liter engine
weired..
how can this be?
Old 10-21-2003, 06:56 AM
fuzzy02CLS's Avatar
Mobil 1 5W~30W
Old 10-21-2003, 06:59 AM
Blk03S's Avatar
Originally posted by fuzzy02CLS
Mobil 1 5W~30W
-Jon
Old 10-21-2003, 07:01 AM
juniorbean's Avatar
Received 1,760 Likes on 1,046 Posts
I use Redline Synthetic 5w20 oil with an Amsoil filter. Change it about every 7500 miles.
Old 10-21-2003, 07:12 AM
Masshole
tmk70's Avatar
Valvoline 5W-30 regular oil, change it every 3K miles.
Old 10-21-2003, 07:15 AM
lover and fighter
r10apple's Avatar
Royal Purple 5w-20; change every 7k miles...
Old 10-21-2003, 07:22 AM
danny25's Avatar
Amsoil 5w-30 with an oversized Amsoil filter. Change the filter every 5k miles and the oil at 10k.
Old 10-21-2003, 07:24 AM
Floyd Mayweather Jr.
Black CL-S 4-Life's Avatar
Re: What kind of motor oil do u feed your cl or other vehicles
Old 10-21-2003, 07:34 AM
allmotor_2000's Avatar
Royal Purple 5W-30... every 5K miles
Cost Drivers!!!!
Zapata's Avatar
amsoil 5w-30 7-10k
Old 10-21-2003, 07:35 AM
Doin' da crack shuffle
Red-CL's Avatar
Mobil 1 5W~30W
Old 10-21-2003, 07:36 AM
123's Avatar
dino oil Valvoline 5w-30
Old 10-21-2003, 07:39 AM
thai's Avatar
chevron or any high quality conventional dino oil is just as good as synthetic if you change your oil every 4-5k or under.
so chevron dino 10-30 every 5k.
Old 10-21-2003, 07:45 AM
Bagged hybrid
BoostedM3's Avatar
Originally posted by Zapata
amsoil 5w-30 7-10k
Old 10-21-2003, 07:46 AM
Go Cowboys.. woo hoo :)
gholdin's Avatar
Amsoil 5W-20.... Only the best for my baby
Old 10-21-2003, 08:06 AM
rchavis's Avatar
Amsoil 0w-30
Old 10-21-2003, 08:27 AM
Mr Zipps's Avatar
Valvoline 5w 30 synthetic every 4k...
Old 10-21-2003, 08:38 AM
cl_type_s_03's Avatar
Royal Purple 5W-20... every 4K miles
Old 10-21-2003, 08:40 AM
A-CL nub
ktown378's Avatar
mobil 1 5/30
Old 10-21-2003, 09:04 AM
Where is my super sauce?
Slimey's Avatar
...and what i found weired is..
weired..
how can this be?
It probably has to do with CAFE standards that Honda & Ford are following. I say probably because I've never seen any proof of this, although the argument is compelling. Some folks that are in the oil sales business state this as a fact, but I've yet to see their proof.
Basically, CAFE is a policy that the auto makers are trying to follow. It describes environmental concerns that the manufacturers should have. The long and short of it is that putting a thinner oil in the car probably increases the entire fleets MPG by 1 or 2, and this makes the manufacturer look more environmental. For Ford, this is a real issue, as they manufacture a lot of gas guzzling trucks. For Honda, I'd guess it's more about an environmental-conscious image as they have very few guzzlers (if any) in their fleet. Do a google search on CAFE if you want to know more.
My 2003 Acura CL-S also has the 5W-20 requirement, as does the 2002 model year.
You'll probably be fine with both 5W-20 or 5W-30. I wouldn't worry about it too much.
Old 10-21-2003, 09:06 AM
joedokes28's Avatar
Mobil 1 5W~30W
Old 10-21-2003, 09:18 AM
whoXwanXsum
dbox's Avatar
royal purple 10-30 in the cl and the lgs. change it every 6k
Old 10-21-2003, 07:21 PM
Lead Footed
RUF87's Avatar
I've been running a mix of 0w & 5w Mobil 1 for 2 yrs, but am switching this month to NEO 5w-30.
Ruf
Old 10-21-2003, 07:24 PM
///M POWER
darrinb's Avatar
mobile 1 every 3-4k
Old 01-02-2004, 01:58 AM
Jimmbbo's Avatar
Re: Re: What kind of motor oil do u feed your cl or other vehicles
Originally posted by Slimey My 2003 Acura CL-S also has the 5W-20 requirement, as does the 2002 model year.
You'll probably be fine with both 5W-20 or 5W-30. I wouldn't worry about it too much. [/B]
Still figuring out which way to go, but synthetic is likely to get the nod - too many plusses with lubricity and high temp stability and much lower carbon formation, and no significant monetary reason not to use synthetics with their extended change intervals.
5W is great for easy winter starting and getting things oiled up quickly. I believe I will be using 5W-30 due to summer temps in the desert....
Am trying to figure out which brand of synthetic to use .
Jim
Old 01-02-2004, 02:03 AM
tiremanjd's Avatar
Its Mobil1 for me
Old 01-02-2004, 07:31 AM
ChucksTL_RENAMED's Avatar
First 80K miles Mobil 1 5W-30, second 80K miles Amsoil 5W-30 every 5 to 6 K miles with a Wix filter, '00 TL still burns, drips or uses no oil between changes......odometer now at 164K....so far so good!
Old 01-02-2004, 07:47 AM
Homeless
chef chris's Avatar
Vegetable with a splash of Peanut.
Good for better gas mileage.
Old 01-02-2004, 07:53 AM
Someday pigs WILL fly!
gto2050's Avatar
Whatever Infiniti recommends.......
Old 12-24-2008, 11:51 PM
5th Gear
archangelnj25's Avatar
bringing an old thread back. ive been using pennzoil platinum full synthetic 5w30 oil now in my cls motor for the past 15K miles since my swap. ive noticed that on my first oil change about 5K i drained it into a large oil bucket and didnt pay attention to how much oil drained out. on the second oil change i drained it into a pan and noticed i drained only 1.25 Qts out. i thought it was a mistake soo i rechecked several times and no more would drain out. now im like 3K after last oil change and the oil pressure light has been coming on during high rev acceleration or sharp cornering. checked oil level and was really low. added like 2 qts to get to normal level. i was told that i need to go to 5w20 semi synthetic oil. bc the full synthetic 5w30 is being broken down quicker. ive checked for oil leaks but the motor is spotless. prior to the swap all seals, gaskets, etc on the motor were replaced before installing to prevent any leaks in near future. im using a K&N high performance oil filter(the $12.00 filter). i could have the j30a1 dipstick and not the j32a2 dipstick bc they look the same but i think they are different lenghts. what motor oil is eveyone running in their cls????
Old 12-25-2008, 12:14 AM
i heart latin chicks
nbennettksu's Avatar
Candy BAAAAARS
Old 12-25-2008, 12:52 AM
Not Asian
phipark's Avatar
Mobil 1, switch between 5w20 and 5w30. Depends on what's available in the 5 qt containers. No problems whatsoever with burning oil.
Old 12-25-2008, 01:12 AM
Ralphie917's Avatar
i just stick with whatever i start with for the most part --- have been using royal purple in the CL
Old 12-25-2008, 05:38 AM
YeuEmMaiMai's Avatar
my car a 2002 CLS what acura puts in when they change it. I don't drive it hard and change the oil every 5 or 6K
my 2007 Yamaha Vino 125, Mobil 1 since:
1. high tolerance for heat as engine is air cooled
2. spends most of it's life near 9K
Old 12-25-2008, 11:08 AM
Elijah J's Avatar
amsoil 5-0
Old 12-25-2008, 07:30 PM
2K1CLtypeS's Avatar
Royal Purple 5w-30 for the CL
Royal Purple 5w-20 for the CR-V
Every 6 mos or 6k miles
Old 12-25-2008, 09:13 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
If your using that much oil you have serious problems. It shouldnt use that much oil period.
I run 5w20 full syn for 10 to 15k mile intervals
Old 12-25-2008, 10:43 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,394 Likes on 4,939 Posts
weired..
how can this be?
Sorry to correct you and go off topic, but the Civic was never available in with the K24. The Element motor is the same as the older Accords.
Back on topic, Mobil 1 synthetic, but this past change I wasn't able to get Mobil 1 (sold out, wtf?) so I used Castrol synthetic. I will go back to Mobil 1 though.
Old 12-26-2008, 11:26 AM
I Wanna Beer
TheWeez's Avatar
Mobile 1
Old 12-26-2008, 12:37 PM
Wide Body 3.2 CL-S
krazykrnboi's Avatar
mobile 1
Quick Reply: What kind of motor oil do u feed your cl or other vehicles
