what happened to xs headers?
#123
Originally Posted by CLS6SpeedNupe
where can i get those from, i was just gonna take the ones that came wit the headers and go some place and tell them i want the bolts but stronger ones. What kinds of stores would have them.
#126
I Wanna Beer
From what I've seen it seems most people either reuse the stock one or install a new factory one and don't use the one that comes with the headers.
#127
I just picked up a set of CL Manual Trans headers on ebay - new for $140 shipped.
They're stainless - and have "spoon sports" welded to them. They have serial numbers at the base of the upper manifold on both pieces - and are much nicer quality than the OBX headers I had on my CL-P.
They have the flex pipe bubble on the front piece of the A Pipe, and I had no fitment issues after I took the jackstands out from under the swaybar mounts (needed to be on the frame to get the rear bank into position on the head).
I don't feel a tremendous gain like I did on the CL-P - but it definitely pulls harder in VTEC. lower revvs.
I doubt that they are Spoon Sports - but they are nice headers for the cash when options are very limited.
PM me and I'll link you to the seller if you're interested.
#128
Originally Posted by pavan87
Has anyone used the stock O rings or did everyone use the ones that came with the XS headers?
#129
I Blaze Up In
you guys are saying to use 10 x 40 bolts...my question is if that is in metric or standard??? And does anyone know if the bolts used for the stock manifold are standardor metric???? I am planning on installing mine soon and i need to know
#130
#131
Caffenine Addict
is this the correct link to the headers? http://xs-power.com/honda/honda027.html
#138
2003 Satin Silver CL-S
Ok everyone is saying different things about the bolts/gaskets/o ring
So 8.8 stength 10x40 1.25 bolts, new factory o ring, new factory head to header gasket? What about the other gaskets?
#139
#140
Originally Posted by DAVERUBINO
All you need are the bolts! Re-use your factory head to header and the o ring gaskets are fine. All they do is seal the different pieces. Unless you kill your factory gasket, it's fine to re-use. That's what I did and I've had mine for over a year with no problems plus I did it myself, no sweat!
I have a nice set of hand tools and a torque wrench, how easy is it to do your self. What should I expect to pay if I have it done
#141
It is actually cheaper/easier for me to buy a whole new set of header's than try and fix my leaking flex pipe, LOL.
...I just placed an order for a 2nd set, just for the A-pipe.
#142
Unregistered user
#143
Originally Posted by LIPPSTUH
won't they just send another leaking one? that's the problem with xs so far. resonance and leaks from the flex pipe.
My big issue is finding time to take my car to a shop to figure out if/how we can repair the pipe. I will just repair the bad pipe(s) on my own time and sell that set to recoup some of the cost.
#146
SOLD
Yes the headers will fit all AT 3.2s...not the MT though because of the tranny. Scoop them while they are hot, I paid 115 plus 15 shipped and almost feel I got ripped now
My friend has driven in his car on the highway with me doing WOT and he describes it as "a little rice sounding but sick as hell".
#147
Go for it and good luck!
#148
#151
i paid 97 bucks too, they are just giving these things away. Is there a gasket that goes from the pipe to the CAT? If so do we use the stock one or the one they give us (havent gotten mine in the mail yet)
#152
I'm not sure. I guess i'll find out when I get mine. I've read on here that the stock ones will work better than the ones that they will send, if they send any for that part of the exaust. If anyone knows can you please let us know??
#153
Just a quick question. Will these XS headers make you fail a smog test? I've heard that the comptechs are CARB certified(are the XS ?), i don't know what that means, but i figured it meant they would pass smog. Just wanted to know.
#154
SOLD
Originally Posted by Bobster
The XS headers will work for the 6MT. The one rear pipe is bent to allow the rear mount. We just got finished doing a full J32A2 / 6MT in a 99 TL using XS headers.
EDIT: Even though the XS headers are not CARB stamped, I wouldn't say they are necessarily illegal.
#160
Trolling Canuckistan
Originally Posted by LiquidCLs6
i just ordered mine yesterday, i cant wait to get those babies in!! hopefully the install goes as smooth for me as it has for some of u guys.
I would highly recommend wrapping them before the install. It cuts down on the tinny sound you get from the thin walls, but you still get more rumble than stock when you give it some gas. You also will hold more heat in the pipes which will help the hot exhaust gas flow more freely. It took me 2 rolls of 50'x1" wrap to cover the whole kit.
