What happened to the electric Supercharger?
No, I didn't research that product...
However I did find that a $1500 investment would get you about 2-3.5lbs of boost using the 12v turbodyne turbo. And it could be used in parallel with another electric turbo. To produce about 6-6lbs, however you would have to do some electrical upgrades with two.
Originally posted by ModAddict
Snake oil!
Snake oil!
Umm no, they already are in use in vehicles all over europe. Mainly in trucks though, and are the 24v series.
Might want to do some research before saying things like this.
It's essentially a garrett turbo (not sure which model specifically)... with an electric motor driving it instead of an exhaust turbine.
http://www.dieselnet.com/news/0002honeywell.html
Looks like Saab has some interest in it too..
http://popmech.popularmechanics.com/...ne/print.phtml
http://www.engr.unl.edu/~ethanol/article9.htm
I was picturing a hair dryer!
I've never seen that before. That looks more like snake vennom!
Smitty, snake oil is used to cure all of your ailments, and is usually sold by a traveling gypsy.
Ah.. Since now the CT SC would output only 3 PS or less. The Turbopac 1500 would do the same at $1500 a saving of at least $3000 over Comptech SC and this for sure a DIY on weekend.
I may be of interest to me to contact Turbodyne, have a custom prototyped on my CLS and then offer a Turbopac kit for a GB.
What do you think? anyone interested?
I understand the functioning of the supplemental systems with a full turbo vehicle where the electric motor is there to basically eliminate the boost threshold.
But this is an electric motor driving a compressor. A turbo compressor's speed is controlled by the turbine speed which is controlled by the wastegate re-routing the exhaust gases. How is the speed of this electric motor being controlled?? Is it using a variable DC voltage motor controller or a pulse width controller?? Regardless, what is the control signal source, RPM??
It can't be an on/off device always running at the same speed; it has to have a variable speed controller. Otherwise you would have say 10 PSI boost at idle and 0 boost at 7k revs, just an example.
In other words, the compressor is just a small part of this; there would be many more components.
What is being mentioned in the link are units meant to supplement an existing turbo application. Not a stand alone eletric turbo:
The Turbopac™ is installed between the air intake system and the turbocharger in vehicles with existing turbochargers. This new product is said to provide faster acceleration, better fuel economy, and an emission reduction.
According to this link it is an On/Off device only giving the extra power at WOT and not giving constant boost pressures:
The Turbopac 2500 is switched on at wide-open throttle and provides a maximum of 3.5 pounds of boost that trails off as engine speed rises.
It's not exactly like having a regular turbo. Quite a bit different.
It was originally designed to create boost at low RPMS on vehicles with exhaust driven turbos. However others are trying to use it for other applications.
Boost trails off since it would require more power to produce the same amount of boost at higher RPMS. The boost is (I assume) static it will reach a point and drop off very rapidly.
I had a chart of boost/rpm but I don't know where it is anymore... I had guessed a 20WHP+ increase from using this device. All theoretical though. (throughout the RPM band it aided)
so that would be great for light to light racing and off the line launches. Its not worth it for a mod that will work well only in first gear for a few rpms, then drops off once i am in v tec at high rpms when driving hard. It will be good for highway cruising and giveing extra power low in 4th and 5th gears for passing so that you dont have to downshift. It sounds good for down low driving, but once you get on the car it will drop off, and if there is something in the path of the intake or exhaust not doing anything at high rpms will we loose power
Iam sure that it will keep a boost all across from low rpms to hi rpms.
The e-charger will spin at constant speed starting from the moment you go WOT, at any rpms!
Now at low rpms you build boost but no much cfm are needed so the excess should go through the waste gate. At hi-rpms the engine will eat most of the cfm you boosted and less air will be wasted.
Simply the boost is not depending on the rpms.
It is possible to have an intellignet controller (boost controller)that spins the turbo at variable speed to keep the cfm as a function of rpms and assuring a constant PSI boost. I think the waste gate will do just fine as well.
More or less, the e-charger is NOS-like with no bottle!
The only real solution is turbo or S/C for continuous power.
An intelligent controller and a dump valve?? Now you have taken a simple device and made a complex and costly system for minimal gains. This is not how any of the articles mentioned it being used and something which certainly couldn't be used on a MAF equipped vehicle, not relevant in this case.
This would be a great way to get a sine wave of power output though and I wouldn't want to be the one to tune that PID loop.
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Joe Avesyan
09-29-2015 03:57 PM
