Weird Light Problem
Old Jun 3, 2003 | 10:11 AM
Tight-S's Avatar
Weird Light Problem
My wife came home yesterday and told me I needed to turn the lights off on my car. I thought hmmm, I didn't have the lights on, what's up with that. I go out to the garage and sure enough they are on but the left light is flashing. Bare in mind that this is the headlight not the turn signal. I then get in my car and sure enough as I thought the lights were not turned on. I turn the light switch to on and back off and they go off. The lights seem fine now. Has anybody had this happen before?
Old Jun 3, 2003 | 11:40 AM
6speedctrlfreak's Avatar
OMG listen to this....I was coming down RT. 22 in Upstate NY and the troopers had a "seat belt check" roadbloack going down and they pulled me over the trooper said my headlight was out.....I said what??? this car is almost new ...I pulled over and sure enough the drivers side was out.....Then I turned them off the turned them back on of course they both work !!! that was Sunday. Anyone else have this happen ???
Old Jun 3, 2003 | 12:09 PM
Smitty's Avatar
No!!!..Gees O petes, I am going to have to keep an eye out for that...
What you driving Tight-S?... 01,02,03 6 speed or auto?
Old Jun 3, 2003 | 04:39 PM
Tight-S's Avatar
2002 CL-S w/ 29,500 miles
Old Jun 3, 2003 | 10:52 PM
FTM-1's Avatar
I have had my 2000 TL for over 3& a half years now. I use my headlights all the time since day one of ownership since HONDA/ACURA did not put in daytime running lights for our U.S. model cars. About 2 years ago I turned on the lights as normal in the daytime & notice the drivers side out when I pulled up behind another car & could see no reflection from that light. When I checked for sure after driving aways it was out. I turned them OFF & then back ON & that light powered back up. I have not had anymore problems in way over2 years & I use them all the time when driving.
Old Jun 3, 2003 | 11:02 PM
Ultimac's Avatar
You threw a valve and that is causing you lights to go out, your car is SCREWED!!!! No I'm just playing... obviuosly. Sounds like a problem with the capacitor or the ballast. It is probably getting to hot and shutting itself off. They boost the voltage like 200times to get around 25000 volts, thats why it says do not mess with can result in death..It could be that you are grounding out, it also could be that the gauge wire was estimated too small, or it could be the heat issue from the ballast. I would say take it to the dealership and get them to fix. On the Upside of a disaster, if you happened to crash, and you could indentify the light as the reason you'd have a New NSX and a FERRARI and probably whatever else you wanted courtesy of ACURA
mada51589
Jan 9, 2025 04:40 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
brandnewcolony
Sep 12, 2015 10:39 AM
HeloDown
Sep 8, 2015 06:51 PM
