Wax On - But How Wax Off?
About 6 months ago I went on vacation and left my car at home. Pops thought it would be nice to wash and wax my car. Well, he used Nu-Finish wax. Now, the Nu-Finish seems to be "flaking" off (little white specs on the car, only come off when scraped off with my fingernail). I want to remove the wax and go back to Zaino. Any ideas?
Does dawn take off Nu-Finish? I believe its a polymer.
Hey, sorry about placement, posted to the detail forum first but only got 2 responses...hoping for some more here.
Received 1,080 Likes
Originally posted by Zapata
Yes, dawn will take off anything.
Only carnauba can be removed with dish soap. NuFinish is a polymer and there is no way you're gonna remove it with dish soap.
I posted the answer for you in the detailing forum a while back....
Nope, you gotta use either isopropyl alcohol or an abrasive, like 3M SMR with an orbital or rotary buffer.
Trust me on this one. Isopropyl alcohol or an abrasive.
You Fawkin Kiddin Me!
do you want an easy solution?! go to your local autoparts store and buy WAX and GREASE remover... usually a spary... spray it on and do a panel at a time.... you will use it like windex.. spray on wipe off... you will most llike not see it come off, but once it is done, you will feel a change in the finish of your car... than wax with whatever... IT WORKS!!!
Originally posted by crazymongol
dawn soap, clay bar. do a search on this topic im sure u will find alot of info
Again -- Dawn will NOT Remove a lot of synthetic products and depending on the situation abrasives and/or clay should NOT be used as a "stripping" agent.
You can use products like:
http://www.griotsgarage.com/search.j...ext=paint+prep
"PAINT PREP REMOVES OLD WAX AND POLYSILICONES FOR A CLEAN START
If you've been using other brands of polish and wax, they may contain silicone and synthetic oils. Our car care system doesn't bond with these silicone-laden products. It's important to use Paint Prep to remove all of the old waxes, polysilicones, and oils so our care products can properly bond to the surface..."
You can also use Prepsol...
http://www.dupont.com/finishes/eu/ma...degreasers.htm
As for the Alcohol, some stuff (like the Zaino) doesn't just "fall off" with a wipe or two (The Isopropyl comes in a variety of strengths, and even the 80% stuff was having a tough time removing about 14-coats to get to a tiny sap mark. (I needed to hit the area with Alcohol. and 39009 and it took a lot of time to strip the stuff back...)
Finally, if you have swirl marks or damage that needs a "buff-out" anyway, you probably can just use a combination of a the Prepsol or Griot's product listed above and a "proper" polish to get a nice surface to "build-on”…
Originally posted by NSXNEXT
I guess you could use the SMR by hand, but you'll be plenty tired once your done.
Originally posted by bojangling
Thanks for the advice...any special way to apply the isopropyl alcohol? Diluted etc...Where to I purchase?
Here you go. 99% Pure Isopropyl Alcohol
You can also go and check your local pharmacy. As EricL mentioned, it needs to be as close to 100% as possible.Lower % will work, just might take more elbow grease.
mugen_kid
11-13-2015 10:38 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SinCityTLX
55
10-11-2015 01:20 AM
