Water leak Sunroof / Moonroof
It is raining today and when I drive my 2003 CL Type - S around some normal corners, I encounter about 20 drops of water falling from the sunroof. The sunroof is closed all the way and it shouldn't be leaking any water. The water is coming from the large U shaped piece of black plastic that is on the driver's side of the sunroof. I plan on checking the 4 drain holes that normally drain water away.
It doesn't appear to be associated with the drain holes because this U shaped piece of plastic is further in from the edge of the sunroof and I can't figure out what could be causing this.
Anyone have any ideas?
Anyone had this kind of problem?
This all started happening about 2 weeks ago after Atlanta had a major ice storm which covered the entire top of the car in a half inch of ice.
haha I had this problem before and from experience take your car to the dealer ASAP. Tell them to replace your entire moonroof/sunroof assembly and also check all the seals around the sunroof as well. After the dealer trying to fix this problem three times I've been having electrical problems every once in a while. So hope you get the car fixed immediately before water starts damaging stuff.
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
