Valve Adjustment Symptom
Old Nov 17, 2008 | 08:19 PM
Allout's Avatar
Blown is Best
I was having a problem with my car dying when it was cold. At first, I thought it was my IAC valve and replaced it - no significant improvement. I couldn't isolate the cause of the problem so I sent it to the dealer to have them help me diagnose the problem. They said all looked fine except that the MAP sensor was showing a lower than normal voltage at idle. Their recommendation was to do a valve adjustment since the lower voltage could be caused by valves being too tight. I was skeptical but took the car home and did the adjustment over the weekend. To my surprise, the valves were on the tight side. After the valve adjustment and a fresh set of Iridiums, the car runs and idles fine once again.
The tight valves causing an idling problem was a new one on me.
Old Nov 17, 2008 | 10:17 PM
RUF87's Avatar
Lead Footed
Wow . . . that is a new one. I think I need to do that soon as well.
Thanks for this little tid bit.
Ruf
02 WDP TLS Black Interior w/ Black Grill Inserts
**1/4mile 14.46 @96.07MPH
(**pre headers, CAT, IMMs & BBTBs)
17x7 Konig Appeals SMF -
P225/45ZR-17 Bridgestone RE960 AS
(used Ziex 512s track only)
CT Icebox, RamAir, Sways & Springs
3nd Gen Innovative Motor Mounts
BBTBs, Mugen Cooling Mods & Thermoblok
Ceramic Coated XS Headers & Random-Tech CAT
NEO Anti Freeze & 5w-20 oil
Tranny #3 Installed 11.17.2008
Old Nov 18, 2008 | 06:01 PM
djarovsky's Avatar
See this thread for discussion on a valve adjustment.
https://acurazine.com/forums/showthr...justment+valve
....and the input from the dealer tech makes sense, per this Acura tech line summary article (first bullet point).
http://www.in.honda.com/Rjanisis/pubs/TS/BTS050802.PDF
Did you take any measurements on the valves before adjusting them? Metrics are key references that would help the forum.
Old Nov 18, 2008 | 08:23 PM
Allout's Avatar
Blown is Best
Good information djarovsky. I wish I would have read that Tech Line article previously as that cleared up a lot of my questions.
I set the lash to .009" and .012" after speaking with a tech at the dealer. The clearances before the adjustment were all over the place but all were on the tight side. I probably opened up the adjustments anywhere from .001" - .003". on both intake and exhaust.
Your information in that previous article is right on the money. Thanks for confirming.
Old Nov 19, 2008 | 08:33 AM
NSXNEXT's Avatar
Having similar problems post-valve adjustment. Geeting my car back to the shop soon.
Awesome post.
Old Nov 19, 2008 | 12:05 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
what do you guys think about the performance aspect though?
http://www.vtec.net/articles/view-ar...&page_number=3
For most people, simply checking to see if the valve is within spec is sufficient. Here at TOV, where maximum performance is desired, we want to adjust the valve to the minimum clearance so the intake and exhaust valves open as much as possible. The RSX-S's K20A2 valve specs are shown below. Please note the differences between intake and exhaust specs!
Intake: 0.21 - 0.25mm (0.008 – 0.010 in.)
Exhaust: 0.25 – 0.29mm (0.010 – 0.011 in.)
Old Nov 19, 2008 | 09:00 PM
djarovsky's Avatar
Given Allout's driveability issues and finding that the valves were tight, you will probably trade a little idle quality and low end torque for high end horsepower. How much and the overall benefits?....you would have to adjust the valves to the recommended specs and to the "performance" specs and do some dyno pulls to compare. Is it worth all of that work and risk in my opinion?....no way....but to each his/her own.
Old Nov 19, 2008 | 11:20 PM
Zippee's Avatar
A few thousands on lash will not make a measureable difference in performance.
Old Nov 21, 2008 | 03:50 PM
jl03CLS's Avatar
6speed
Is it true that the valves are self adjusting? i went into my local acura dealership cause i have a clicking in the engine bay (not purge valve) and 2 different service managers said they are supposed to be self adjusting. my engine is getting loud with whatever is clicking and my tensioner. someone told me changing the oil wieght will help with valve noise
Old Nov 21, 2008 | 05:25 PM
Zippee's Avatar
That is total bullshit, the valves are manual adjusting. Don't even think about screwing around with the oil weight, run what Acura recommends.
Old Nov 21, 2008 | 08:56 PM
Allout's Avatar
Blown is Best
Thicker oil may only mask the problem. You've got to fix the core problem which may be an adjustment.
Old Feb 19, 2009 | 05:35 PM
NSX-Tuner's Avatar
boosted is best
Jeff, glad you got your idle issue sorted out. On a similar thread, I just had Shad change the timing belt, replace the spark plugs and service the S/C. During the valve adjustment, he found several tight valves.
Before this maintenance was performed, the car idled a bit rough and pinged more than normal for cold weather. Now, car runs better than I remember... and no more pinging under a heavy foot.
Old Feb 19, 2009 | 08:21 PM
Allout's Avatar
Blown is Best
I didn't think about having Shad do the timing belt. How many miles you have on yours now?
How's the X doing? Did you ever go with the piggy back tune?
Old Feb 19, 2009 | 11:51 PM
NSX-Tuner's Avatar
boosted is best
I did the timing belt at 104,425 miles, but now I'm neary 106k.
I'll PM you about the X...
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
lowgrowl
Sep 26, 2015 05:18 PM
flybyglass
Sep 24, 2015 01:12 PM
