V6P.Net Ground Wire Kit
Prez & GC, .Net
http://www.v6performance.net/forums/...ad.php?t=32515
Please stop by and vote Acura-CLS
V6P will be offering a ground wire kit for 6th Gen Accords and the Cl-S. A ground wire kit will also be made for the 7th Gen Accord, as well as any other applications that we get enough requests for. The kit contains 5 ground wires which is a 4 guage wire which is 2-3 times thicker then the current ground wires, 2 battery terminals, and the replacement bolts and washers that are needed to install the ground wire kit.
http://f2.pg.photos.yahoo.com/ph/gm...b&.dnm=1ef0.jpg
http://f2.pg.photos.yahoo.com/ph/gm...b&.dnm=8796.jpg
http://f2.pg.photos.yahoo.com/ph/gm...b&.dnm=92b8.jpg
We have installed this kit on Maurice’s Accord, and on a CL-S and both cars are now running very noticeably quieter and are much smoother. The most noticeable change on the CL was the fact that the car has a smooth start. Before the ground wire kit was installed it had a growl to it and also had a jerking feeling to it when starting. Both of these "problems" are no longer there now that the ground wire kit has been installed.
What does a ground wire kit do?
A ground wire kit is a ground… which in this case prevents spikes in electrical signals. Our cars have electrical signals that go from all of the sensors to the ECU and then from these signals the ECU sends out signals that control the engine, air fuel, … When a good ground is not provided it allows for a spike in the electrical signals that are being received and sent out by the ECU. When this happens the signal is slightly modified causing the car to not run the way the ECU intended it to.
It is like when you are trying to talk to someone on a cell phone when you are in a tunnel and the reception is bad. The signal cuts in and out and you cannot fully understand what is being said and neither can the other person. A ground wire kit will give a full and clear signal and remove most if not all of the impurities in the signals being sent and received. This will allow your car to run more efficiently which will allow for better performance.
More information will be provided soon. (Price and availability) The kits should be available in about 2-3 weeks.
I know everyone's already hacked the issue of quality and why buy this when ebay sells one for $35 w/o the battery terminals on the SRP Ground Wire Kit thread, so let's just keep the questions to the kit itself in this thread. Let's give our moderators a break
If you're interested, please vote in the polls on the link. That's helps us determine demand and how many of each kit to make. Thanks!
Dizzy
Dizzy
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
SUPRMN84
10-07-2015 09:46 PM
