Update on cams
Old 10-21-2003 | 09:52 PM
BoostedM3's Avatar
Bagged hybrid
Update on cams
I've been looking into billet cams for the CLS recently and this what I've found so far about our stock cams (from v6performance).
Lobe heights
J32A2: 34.737 (Primary), 36.445 (Vtec), 34.919 (Secondary), 36.389 (Exhaust)
I don't have any extra set of cams (yet), so I can't get them measured for lift/duration and I can't seem to find them anywhere. I know that the AV6 has duration of 194/200 @.050 (non-Vtec) and 215/200 @.050 (Vtec). No lift numbers to be found.
If anyone has a set of CLS cams that they can measure or let me borrow to measure, that would be great. Once I get the specs, the cam shop can make a billet one for me in a couple days and I will do before & after dyno. If gains are significant and people are interested, a group buy of 5-10 minimum can be setup (~$600 or less).
Old 10-21-2003 | 10:06 PM
mattg's Avatar
someone help this man.
Old 10-22-2003 | 12:01 AM
hellas's Avatar
cant you just look up the specs in the shop manual?
Old 10-22-2003 | 04:23 AM
johntypes's Avatar
I in, hurry up we need spec.
Old 10-22-2003 | 07:48 AM
CLS2001_97124's Avatar
Revving at 9K...
This will be the perfect mod after the chip.
Old 10-22-2003 | 10:05 AM
BoostedM3's Avatar
Bagged hybrid
I've asked around and no one knows the exact specs.
Jens, can you possibly find out?
Old 10-22-2003 | 10:06 AM
BoostedM3's Avatar
Bagged hybrid
Exactly
Old 10-22-2003 | 10:53 AM
Revving at 9K...
Actually, before the chip would be even better...
Unless changing the cams won't affect air/fuel, timing and all that good stuff. ???
Old 10-22-2003 | 10:54 AM
MtBikR's Avatar
Ronnie are you going more more agressive cams or just replicating our stock internals out of billet for strenght? If you going for power addition as well, please add me to your group buy. Thanks
Old 10-22-2003 | 11:09 AM
BoostedM3's Avatar
Bagged hybrid
Jens is looking for the specs.
Well, my plan is to get these cams and do before & after dyno with i/h/e/crank. Then after that, I want to see if the e-manage/chip could fine tune it in case the ECU doesn't adjust well with it.
MtBikR - More agressive of course! I still dunno if I need to change the valve springs...some say yes while others say no. I guess it depends on how agressive, but I don't want a rough idle....
Old 10-22-2003 | 11:42 AM
typeR's Avatar
i thought someone had a set they were sending to web cam
Old 10-22-2003 | 11:44 AM
BoostedM3's Avatar
Bagged hybrid
That was me , but i don't want to buy a set just to get it spec'd...only if I have to, then I will.
Old 10-22-2003 | 11:50 AM
typeR's Avatar
ok ...i did a search but couldnt find the thread where you had said that
Old 10-22-2003 | 12:14 PM
BoostedM3's Avatar
Bagged hybrid
This is when you brought up the topic & I mentioned it.
http://www.acura-cl.com/forums/showt...highlight=cams
I've been talking to allmotor about it, so maybe you heard from him?
Old 10-22-2003 | 07:01 PM
BoostedM3's Avatar
Bagged hybrid
Damn, all Jens could find is the lobe height also. I guess I'll have to find a set to get spec'd. I'll keep you guys updated.
agupta3224
05-23-2017 09:30 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 12:43 PM
ExcelerateRep
10-14-2015 09:20 AM
thegipper
09-28-2015 02:01 PM
95oRANGEcRUSH
09-25-2015 01:50 PM
