unsuccessful header install
Old Aug 26, 2007 | 10:35 AM
davepaul033's Avatar
Everything seemed to be black and white until i went to separate the a pipe from the cat converter. I was thinking about just breaking the nuts then putting a new nut on. I also used a impact gun and that just striped the nut. Has anyone had this problem? Help me out guys.
Old Aug 26, 2007 | 12:18 PM
artbran's Avatar
666 Speed
A couple people have. What I remember them doing was taking a Dremel to the NUT and not the stud and cutting off the nut. then somehow or other they got the pipes apart.
But I didnt deal with this as I got my car with headers already...
Old Aug 26, 2007 | 01:03 PM
visuelz's Avatar
East Coast Crew
Since the header gets exposed too very harsh conditions, it would have been better if you used a lot of wd-40 on it the night before or something.
Old Aug 26, 2007 | 01:15 PM
ScottyNorq's Avatar
2003 Satin Silver CL-S
I had that problem yesterday. I broke loose two of the nuts but not the third. I unhooked the entire exhaust dragged it from under my car and put it in the back of my roomates car and drove to a muffler shop. they heated the nut up with a torch and then it came off.
Old Aug 26, 2007 | 02:46 PM
silvervtec96's Avatar
Back to a MT!
I also removed the whole exhaust system and then just ground off the bolts, punched them out and used new ones to connected it back up.
Old Aug 26, 2007 | 02:56 PM
OneUpYou's Avatar
Stand Up , Stand Out
I used PB blaster, sprayed it the night before and a few time the next day. came off like butter
Old Aug 26, 2007 | 03:06 PM
kyle77777's Avatar
Gonna cost to catch up
Most people recommend spraying with wd40 the night before and it comes off pretty easy like the previous poster noted
Old Aug 26, 2007 | 05:55 PM
distortedolskool's Avatar
PB blaster works best, that's what it's made for. worked great on numerous suspensions and my headers. WD 40 is for "Water Displacement"
Old Aug 26, 2007 | 06:27 PM
typeR's Avatar
i recomend pb blaster for breakfast
Old Aug 26, 2007 | 06:28 PM
GreenMonster's Avatar
I've got Liquid Wrench and WD-40 (and a can of CRC I think) in the garage right now, but PB blaster is the best that I've used (which is probably why I ran out)... I've heard Kroil is great too (but is harder to find)...
Basically:
Mapp gas (to heat stuff off) > Kano Kroil > PB Blaster > Liquid Wrench > WD-40
Old Aug 26, 2007 | 09:35 PM
say the pb blaster doest not work, and i have to torch or cut the nuts off? If i torch it wont i mess up the threads? And if i cut them all i have to do is just replace the nuts i cut and i am good to go?
Old Aug 26, 2007 | 09:42 PM
Blasted69's Avatar
03 Anth Type S 6 Speed
As long as you don't mess up, cut to far and hit the bolt. And as we all know nothing ever goes wrong. Right?
Old Aug 26, 2007 | 09:43 PM
if the PB blaster doesn't work the next step would be to heat the nut up and try to loosen it. the chances of you cutting only the nut off with a torch or grinder and not messing up the threads are slim to none, dremel maybe. worse case cut the nut off and replace the bolt and nut.
edit: first make sure you are using a 6 point socket. not one of those crap multi ~24 point sockets. some PB, a 6 point socket and a breaker bar can go a long way!
Old Aug 26, 2007 | 09:46 PM
Bobster's Avatar
I just did this 2 days ago. I had to cross cut it with a dremel and use a sharp punch to finish the job. If ur careful, u wont hit the bolt.
Old Aug 27, 2007 | 08:26 AM
fuzzy02CLS's Avatar
wd40 is a lubricant & rust inhibitor, not a rust penetrator.
PB Blaster owns wd40!
Old Aug 27, 2007 | 08:39 AM
05TLBlack&Tan's Avatar
Talking Well...
I torched my nuts off!!!!!
Old Aug 27, 2007 | 08:54 AM
ok guys i will us pb blaster for about a week each night before i go to bed. If that doest not work i am breaking out the dremel and hoping for the best, anymore info would be great.
Old Aug 27, 2007 | 09:46 AM
Excelerate's Avatar
Former Sponsor
If you already rounded the nuts PB Blaster isn't going to you help you.
You have 3 ways to do this:
1. Torch them off. I'm not talking a torch that you buy from Home Depot. You need an oxy-acetylene torch and generally only shops have those.
2. Cut them off w/ a dremel, grinder, sawzall.
3. Get something like this to remove rounded nuts.
http://www.sears.com/shc/s/p_10153_1...d=rounded+nuts
Old Aug 27, 2007 | 10:34 AM
Yeah I allready broke a non impact 13mm socket, when i used the impact 13 mm just striped it out. I think i may cut it off. Doest anyone know the exacy size of the bolt/nut i will have to put back on there?
Old Aug 27, 2007 | 10:43 AM
ScottyNorq's Avatar
Take them to Napa Auto and they will be able to match up the old ones with new ones, thats what i did
Old Aug 27, 2007 | 01:10 PM
thanks for the info again and again
Old Aug 27, 2007 | 01:11 PM
LukeaTron's Avatar
These kind of tools are the easiest way I've found to remove a badly seized nut without messing up the bolt:
They're a lot easier to use in tight spaces than just about any other method.
Old Aug 27, 2007 | 03:30 PM
ooo damn. i never knew those existed. looks to be handy in some situations.
and one hell of a name also!!
the Nut Splitter
Old Aug 27, 2007 | 03:36 PM
kyle77777's Avatar
Interesting tool, never seen or heard of them
Old Aug 28, 2007 | 09:30 AM
I am going to buy those today!!! they look like they will get the job done
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
CLsuperhero
Sep 23, 2015 12:53 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
TxRzrBk
Sep 17, 2015 01:07 PM
