Turbo Install Update...
Old Jan 23, 2003 | 06:50 PM
allmotor_2000's Avatar
Folks.
I will be done by this weekend and hopefully have it running by Sunday. It might run great right off the bat... or might need some tuning and additional tuning work... I don't know. The installation should be completed by Saturday and I will take pictures at that time as I really don't want to take pictures of half-completed work.
Since I have actually changed a few things since I conceptualized the project... here's what is like now:
T04E turbo:
* Chose a rather big turbo for a few reasons. One is that I never have to upgrade my system if I build the motor... this one is capable of about 850hp. Since I am initially boosting about 5.5psi... spool-up should be around 3300 RPM. A T3 would choke on a 3200cc V6 at 6K RPMs and above
Tial 46mm HP wastegate:
* This is the MOTHER of all wastegates. It is used as the upgrade wastegate on the Porsche GT2 race-cars.
Spearco Intercooler:
* I had this custom-made for me. It has a 2 1/4" ports where the return is off the top. It's 24"x3.5"x6.5" (LxWxH)
Comptech FPR:
* I had originally chosen a Vortech 'piggyback' FMU. This caused all sorts of problems with the car and I ended up using a Comptech FPR. This is fully adjustable and is a very good unit. It is used on all the Comptech S/C kits. It uses Earl's fittings and is a solid system.
Blitz Blowoff valve:
* I just got the basic blow-off valve
Synapse MAP Boost Limiter:
* This goes in series with the MAP sensor to eliminate it from reading boost.
Walbro in-tank fuel pump:
* This is a 250 lph unit that fits in the tank and should provide enough fuel for upto 450hp
AutoMeter Boost Guage:
* Just the 'phantom' face boost-guage with a custom-made pillar mount
Mugen T-Stat & Fan Switch:
* Just some anti-detonation measures. Along with some water-wetter it should reduce any 'hot-spots' in the cylinder head that could cause pre-ignition. The operating temperature of the motor is also reduced by a few degrees
Manifold:
* I decided to spend the extra $$$$ to get this done in stainless-steel. It's much stronger and better quality. I have asked my fabricator to make this of the same thickness as the Comptech Headers. I am using the upper (manifold) section of the Comptech Headers and replacing the A-pipe to one that will feed the turbo along with a down-pipe. The wastegate dump-tube will feed back into the exhaust. The turbo will be mounted to the tranny-mount (so that the manifold will torque with the motor... and not crack!). The downpipe will have the flex-tubing like the Comptech to accomodate for the motor torquing.
Honestly I expect 300+hp at the wheels at 5.5psi. Depending on how this runs... I might max out at 7psi. This SHOULD give 350hp on 91 octane safely. Anything beyond that (I think the motor can take 10psi)... won't be considered until I have some programmable engine-management-system.
My biggest concern on this whole project is detonation. I have several advantages to the Comptech S/C (for the same boost-level):
(1) Intercooled intake charge (approx 50-70 degrees cooler)
(2) Slower boost-buildup. This lessens the vaccum-to-boost transition and any 'dip-in' effects that might cause a lean condition
(3) Lower engine-operating temp and reduction of any 'hot-spots' in the cylinder-head
I will post a follow-up to this with pictures over the weekend!!
Old Jan 23, 2003 | 07:28 PM
trodery's Avatar
Sweet... Too bad you can't do a RWD conversion... that'd be fun!
AGPExTreMe's Avatar
Sucky Drifter
dayam man.....you need to build me a turbo kit for my tl-s hehehehe if you dont mind me askin....how much did it cost for everything?? agp
Old Jan 23, 2003 | 07:31 PM
Loseit's Avatar
Changin bulbs since '73
good luck man!! sounds good.
take some video if you can!
Old Jan 23, 2003 | 07:36 PM
Video
I don't have one of those digital cameras that take .mpeg's, but I
might be able to borrow one.. we'll see.
The cost is very competitive with the Comptech S/C, except for this particular setup where I used a very expensive turbo and wastegate. Basically you get much more goodies and "bang-for-the-buck"!
Old Jan 23, 2003 | 07:42 PM
trodery's Avatar
Re: Video
That is a nice turbo and wastegate. What's the A/R on that turbo?
Old Jan 23, 2003 | 07:46 PM
ch1276's Avatar
WOW.....I can't wait to see the finished product
Old Jan 23, 2003 | 08:00 PM
mattg's Avatar
this is the most exiting cl news in a long time, props to you.
Old Jan 23, 2003 | 08:03 PM
cusdaddy's Avatar
Good luck! Sounds like you have an amazing setup.
Really exciting news. I can't wait to see/hear about how it goes.
Old Jan 23, 2003 | 08:09 PM
mantis23's Avatar
Moderator Alumnus
x 100
I hope all goes well with the finishing touches
Old Jan 23, 2003 | 08:17 PM
EricL's Avatar
Are you planning a water spray setup to cool down the intercooler?
PICS -- Please!
Sounds nice!
Pics from another one run off the window washer bottle/pump:
Old Jan 23, 2003 | 08:18 PM
EricL's Avatar
Old Jan 23, 2003 | 08:34 PM
importtuner's Avatar
You should consider using an AEM managemnt system; I've seen a huge success as well as remarkable gains with it!!!
-Justin
Old Jan 23, 2003 | 08:40 PM
SiGGy's Avatar
Moderator Alumnus
PICS -- Please!
Sounds nice!
those your pics?
If so, what application did you use those on?
Old Jan 23, 2003 | 09:02 PM
darrinb's Avatar
///M POWER
congrats, hope it all works out, cant wait to hear from ya on sunday
Old Jan 23, 2003 | 09:07 PM
4pumpedCL's Avatar
Honkey
I give you props, man. You've got gonads, but that's what it takes to build an awesome car. I can't wait to see some pics! Keep us posted
-Aaron
EricL's Avatar
Originally posted by SiGGy
those your pics?
Audi link.
I don't have pics, but we did something similar on a buddies RX7 turbo...
The power would go WAY UP on a dry day!!!
The misters come with "drip systems" and also for cooling patios in dry climates...
Old Jan 23, 2003 | 09:11 PM
I haven't really thought of the intercooler-spray... although it might be an option down the road.
AEM currently doesn't have a system out forthis car that's plug 'n play. I suppose I could get the generic system and wire the entire thing... but I don't want to do that.
This isn't my race-car... its a daily-driver... and one day I would want to sell it... so I don't want to go down that route.
Knowing me I'll get bored of the turbo and sell it within the year
Old Jan 24, 2003 | 04:25 PM
Update
It might be Sunday now... few hiccups... but don't want to rush it.
Old Jan 24, 2003 | 04:32 PM
6spdmanual's Avatar
Can't wait to see the result. But can the transmission handle this??
Old Jan 24, 2003 | 04:34 PM
CLS2001_97124's Avatar
Revving at 9K...
Sweet, let have another west cost meet when you get done and broken in. We should have a show down between the Comptech S/C against your Turbo!!
Old Jan 24, 2003 | 04:55 PM
The 6spd should easily handle the power.
A meet sounds OK... we'll see when its done completely.
Old Jan 24, 2003 | 05:59 PM
TKO's Avatar
TKO
Can't wait to see the #'s it makes...good luck on that man!
Tape some video if you can of it on a dyno or something.
Old Jan 24, 2003 | 06:01 PM
I'm down for that... who has the 6spd with the Comptech S/C?
Old Jan 24, 2003 | 06:13 PM
CLSmike's Avatar
TheCarBreathesNitrousToo!
Shit I wonder what you will run when all the kinks are worked out
hopefully higher than a 13.5 lol...
Old Jan 24, 2003 | 06:17 PM
PerFecto's Avatar
All you 2nd gen guys get all the good stuff!
Old Jan 24, 2003 | 06:32 PM
oghondaman's Avatar
Old Jan 24, 2003 | 07:06 PM
I am pretty sure I'd hit 13.7 or 13.8 NA... so I am expecting 12's with the turbo... hopefully
Old Jan 24, 2003 | 07:42 PM
bryanz3.0cl's Avatar
nothing
you'll definately be in the mid/high 12s. im in aww, finally somebody had the guts to do a turbo.
Old Jan 24, 2003 | 07:51 PM
mc222's Avatar
I hate the Mets
Im like a little kid waiting for christmas---and it isnt even my car!
Old Jan 25, 2003 | 01:00 PM
tuRb0mikEy's Avatar
Who Needs a Type-S?
has this guy posted any pix instead of a bunch of mumbo-jumbo specs?
still waiting...skeptically
Old Jan 25, 2003 | 01:10 PM
I am not even going to comment on this...
Old Jan 25, 2003 | 01:14 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
Please ignore that turbo....your turbo is powerful a week or so we should all see the end result
Old Jan 25, 2003 | 03:16 PM
mattg's Avatar
jealousy can be such a bitch
Old Jan 25, 2003 | 03:34 PM
MCHM3's Avatar
magnet
YEAH DONT LISTEN WHEN I PAINTED MY CL-S VOLTAGE BLUE AND DID THE 3.5 LITRE UPGRADE TO MY CL-S THERE WERE A LOT OF HATERS OUT THERE JUST POST PICS SOON
Old Jan 25, 2003 | 03:35 PM
Happy CL-S Pilot
and your CLS was found in a lake or is that your hooked up Audi?
Old Jan 25, 2003 | 03:56 PM
AkuraCLS's Avatar
ALi G in the House!
dude all i can say is all_motor is for real
Old Jan 25, 2003 | 04:04 PM
mattg's Avatar
lets see some pics of the m3, MCH.
Old Jan 25, 2003 | 04:20 PM
monkeymato's Avatar
Buckle Up
It was his CLS in the lake.
Old Jan 25, 2003 | 04:55 PM
Nihilistan's Avatar
Turbo... MMmmmmmmm
Lookin forward to the next update.
Still planning on clearing the CL?
-- Nihil
