transmission fluid
an asshole from florida
transmission fluid
hey guys..ive got an auto cls and lately the tranny's been slipping..yeah its probably going to go soon but just in case...what is the best transmission fluid i can get? and where?
thanks guys im pretty new to everything with a car so ill have pretty big newb questions
DRINKING HAS A ME PROBLEM
i would not change the fluid specially if you are still under warrenty. 100,000 miles. just let the tranny die if it is going to. and get a new one. dont try to save a dieing tranny.
but if you still want to get the honda ATF fluid from the local dealer. its 3 bottles ($15) per drain and fill.
cool ...yeah my car has about 111,000mi on it. and by slipping i mean when its going from second to third it starts shaking pretty bad.
might want to get ready to bring it in and they may get a goodwill replacement done. being 17 you may also want to bring a parent. not saying anything about you just saying that having an adult there they may be more willing to work with you.
my tranny has 75k, not original. i just did a DIY flush using regular Dexron 3 compatable but added lubegard to make it compatable. the combo makes it cheaper if you dont mind mixing your own fluid. i think it might be better to buy honda fluid but adding lubegard is supposed to make it compatable, but its up to you. i have a rough shift when shifting 2-3 and a flare/slip from 3-4. the shift is smoother but i think the slip is happening more. it didnt used to slip everytime, not it almost does. just my . hope it helps, and good luck
With that mileage on it you may just want to bring it in and see if acura will good will you a new one. The longer you wait the less likely they will be to do so. At that mileage you very well may get a new one.
SidhuSaaB
05-30-2020 12:40 AM
