Transmission Cooler
Transmission Cooler
need help. I bought a B&M tranny cooler #70264 to put in my 03CLS. I was looking for info here at the forums but all the links are dead for this application.
I guess we have a Tranny "warmer" on top of the transmission. Is this where you have to tap in the cooler?
which hoses go to which? My mechanic was confused that my car already has a trans cooler of whic was really a warmer after doing some research.
Can or does anybody have some instructions ? Called B&M and they where no help as to connections with our specific application.
Would appreciate any help. thanks.
You can add one but its not going to help the trans from dying if that is your intent or reasoning behind it.
2nd we need to know if you have the oil jet kit installed?
See this thread for pics to install it.
https://acurazine.com/forums/2g-tl-1999-2003-98/where-trans-cooler-located-888026/
You need to bore out the third gear clutchpack lube passage...so that more fluid gets to it
lanechanger
10-13-2015 10:56 AM
