Trans Dip has 3 holes 2 bottom 1 top?
I have been having trans problems for years, now im beginning to wonder if im just not using enough trans fluid. I have 2 holes at the bottom (i keep in between these) but i also have a hole toward the top, now im thinking maybe im supposed to be filling up past the 2nd hole and in between, theres around a half inch between the first 2 and about 6+ inches from the top to the middle bottom one.
any assistance is greatly appreciated, i bought this as a supposed OEM trans fluid dipstick (has yellow top) a few years back and i cant rememebr what the old one looked like but it seems to be around the same length.
Brings me to next question.
thanks for confirming. So I check my fluid level after driving Freshly cleaned dipstick and I’m seeing fluid past the 2 dots half way up to the top dot. I know I have a trans problem but what does this mean that when it’s hot after running the fluid level is higher. Should o drain some out. Should I let it go cold and see if it’s still that far up ?
When on level ground, If the 'hot' level is above the second mark on the dipstick going up, the trans is overfilled.
I run mine, on my project CL-S, just a tad below the second mark level when hot.
It was way above the second mark when I purchased the car. I removed trans fluid via the dipstick tube with a large syringe and vinyl tubing that would slip down the dipstick tube until I achieved the proper level.
yahelou
01-19-2014 09:26 AM
Thefoodpyramid
1G CL Problems & Fixes
11-01-2011 09:27 AM
