tranny questionS
tranny questionS
K so my tranny shifts weird from 1st to 2nd... not hard engagement or anything but it's not FLAWLESS. Like when i give it 30-40% throttle or more it's all good and it's flawless straight up! I just got the trans rebuilt and it's been like that since i got it back... maybe a week after (i'm not sure if I just didn't notice in the beginning). But I know it's not the trans itself cause everything is new practically. Accept the switches were cleaned and not replaced.
Would a bad pressure switch cause this? or bad trans ECU?
either way it's not a must fix issue, it's just something I want to figure out cause anything that isn't perfect I want to fix!
Don't go thinking I'm in my car and 1st to 2nd is WAM or something. Passengers don't notice it.
That's why I'm pretty damn sure it's a switch or friggin tranny ecu which would be too expensive to make it worth my while.
Can you reset the tranny ecu? or does that happen anyway when you reset the car ecu?
Pham Alvan
03-16-2016 09:17 AM
navtool.com
31
11-16-2015 08:30 PM
