TL Dash Harness ISSUE
I'm in need of some SERIOUS Pointers.... I am looking for Connector "E" From a TSX OR AN RSX to COnnect into my CLs6 ECU. the plug that i Have does not work and i am going to need a connector with the wires to hook up to the dash harness i believe... this is for 6 speed swap and its connector A on the 6 spd, but i believe Connector E is the Same size as the connector i need. Is there ANYONE out there who is willing to Share some wealth of information?
6mt swapped..smart
I had to do the same. It sounds like you understand what you need to do though- Repin the connectors from your old A plug to the new 6 speed E plug. They will be different so you'll have to find the pinouts for each connector on alldata or probably a helms manual or whatever. As for finding an E connector, i'm not sure since I had a complete 6mt dash harness that I took the plug off. Those other cars might have that same plug, again not sure
I think I've Found the solution to my heart attack![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Got a Connector which is the same fit as the Slot A on my CLS6 Ecu
All I have to do now is Repin the wires to the harness and I think i'm good... Man, as if gathering the parts for the swap didn't have me![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
as FAWK
Having to mess with signal inputs and outputs are probably the worst part of this swap..
Now i'm a little![Excited](https://acurazine.com/forums/images/smilies/excited.gif)
this swap's almost over... ![Clap](https://acurazine.com/forums/images/smilies/clap.gif)
![Victory](https://acurazine.com/forums/images/smilies/victory.gif)
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
so I can start to![Zoom](https://acurazine.com/forums/images/smilies/zoom.gif)
in my custom ride
Now i'm a little
so I can start to
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
