Tire Size Calculator
Don't know if any of you have seen this or if it has been posted here before. I just ran across it and thought it might be helpful!! Check it out. It is very cool. Just put in your stock tire size and then the size of the tires you want. It will let you know how they compare in size visually and then calculate if your speedo will be slower or faster and by how much!!! Hope it helps some of you out. Tire Size Calculator
Originally posted by Mike:
<STRONG>It's been posted several times but a refresher is always good.
</STRONG>
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
More links to tire calculators (someone please FAQ this) – this seems to be a recurring theme:
Tire Size Comparisons
Provides a list of all possible tire sizes for 12- to 19-inch wheels. If you want to know every option in a single operation – this is it.
http://www.dsm.org/tools/tiresize.htm
Tire & Wheel Combination Calculator
PURPOSE:
Buying a new set of wheels for your car isn't as easy as some may think. You must take into consideration the wheel's offset, width, and diameter in addition to the tires width, aspect ratio, and outer & inner diameter. If you get any of these sizes wrong, your car may not perform as you would like it to, or it may not give you the look you want…
http://www.venommotorsports.com/howt...ldiameters.htm
Speedometer Error Calculator
(Does more than just what the name says.)
http://www.paspeedo.com/calculator.htm
PURPOSE:
Don't forget this one: http://www.tolan-hoechst.com/cars/tirecalc.htm
Originally posted by e1828:
<STRONG>Don't forget this one: http://www.tolan-hoechst.com/cars/tirecalc.htm</STRONG>
(That one is KILLER for checking out modified wheel/tire fit with offset info...)
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
