TIRE Question
Old 12-23-2002 | 02:45 AM
mr. big's Avatar
TIRE Question
Ive got like about a 2 in drop all the way around and i was wondering, for my 19s, should i get 235/35/19 OR 245/35/19? Does anyone kno if the 245s will rub even more?...will they even fit? the wheels are 19x8....thanks
Old 12-23-2002 | 02:54 AM
Edub-TL's Avatar
Sticky Rice OwnZ joO
yeah the 245 will definately rub more.. the 235 are a very good size.. and probably cheaper and easier to find too..
So what 19" wheels are they??
Because the offset will play a big part in the rubbing or not..
Old 12-24-2002 | 12:51 AM
mr. big's Avatar
they wheels are AXIS 7mod....PICTURE OF THE WHEEL (if u wanna see the pic, u gotta be patient...sorry, large file)
and the offset is 45+....u think ill rub alot?
Old 12-24-2002 | 02:37 AM
Edub-TL's Avatar
Beautiful wheels!!
if you get the 235/35/19, it should NOT rub with a +45 offset.. I think it would only rub if you're taking a turn hella fast or you have 4 people in the car.. otherwise, you should be fine. You might be able to get away with 245, but there is more of a chance to rub than the 235.
I think there are actually some members here who are running the regular se7ven 19x8 with +45 without rubbing issues and a similar drop to yours..
Old 12-24-2002 | 03:02 AM
GOT PSI?'s Avatar
It's Go-Time.
How much did the wheels run you? Which shop?
Old 12-24-2002 | 10:37 AM
Rod's Avatar
Rod
I think you may run into rubbing issues even with the 235/35/19s on a 2" drop. I don't rub with my Se7ens, but I only have a Comptech drop. I believe OUTRAGEOUS CL TYPE S says he rubs with his wheel/tire setup ,which I think is also 235/35/19 19X8 (+45), and his Comptech springs. I'm pretty sure he's the one who said he rubbed in the back because the system in his trunk is pretty heavy and brought down the rear end a bit...which is probably about equal to the 2" drop you have, if not less.
Old 12-24-2002 | 05:41 PM
mr. big's Avatar
the wheels cost me about 325 each...i think, since i got mine in a package deal thing, from AMerica's Tire Co.
Old 12-24-2002 | 07:59 PM
GOT PSI?'s Avatar
It's Go-Time.
Post some pics when they're on your ride!!!
Old 12-25-2002 | 03:51 AM
mr. big's Avatar
of course i will
ron3.7
09-21-2015 12:39 AM
datadr
09-12-2015 10:12 PM
datadr
09-02-2015 07:46 PM
bailey24
08-31-2015 06:38 PM
