Tire pressure on stock shitchelns
i was wondering what psi are your tires inflated at, and yes i used the search function and nothign came out. thx in advance
Originally posted by Scrib
Doesn't the factory recommend 32PSI ATWO? Should say on the inside of the door???
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![:]](https://acurazine.com/forums/images/smilies/redface.gif)
For additional Michelin MXM4 info:
http://michelinman.com/assets/pdfs/doc_pilotmxm4.pdf
Find the text below the table of specs that says:
"For speeds over 100 mph, load and inflation must be adjusted according to table below." Use the table info for the 'V-Performance Rated Tires.'"
You can easily add 2 to 5 PSI to the 32-psi pressure recommended by Acura (35 to 37 PSI).
1fatcrxnem1
22
06-01-2018 01:23 AM
