Tire cupping
Old Nov 3, 2003 | 04:33 PM
Lester_leaps_in's Avatar
Semper Fi
Tire cupping
All four of my Sumitomo HTR+ 235/45/17 tires have noticable cupping on the inside.
What is the most likely cause of all four of them cupping on the inside? I have about 27k miles on them, and have rotated them on a regular basis.
Front end alignment checks out ok, by the way.
I will appreciate any advice or suggestions.
Old Nov 3, 2003 | 04:39 PM
mt6forlife's Avatar
Cupping is usually caused by underinflation but I thought it should be both inner and outer sides.
Old Nov 3, 2003 | 04:45 PM
Aegean_Blue6's Avatar
Daily Driver
are those Sumis sitting on stock rims? I've heard of problems with some tire manufacturers getting 235/45s to sit correctly on our thin stock rims
Old Nov 3, 2003 | 04:54 PM
Semper Fi
Yep, they are on the stock rims. I wouldn't have thought of that as being the culprit. Thanks.
Old Nov 4, 2003 | 07:51 AM
acura_service's Avatar
www.drippinwet.com
mine also, i had the vehicle aligned when i got them put on at my dealership, its been about 1500 miles since i mounted them, and the fronts are cupping on the inner and outer edges, i had him recheck it, and the alignment is fine, i raised my tire psi's to 36psi and have driven it since last week, i have to wait until i put more miles on it to see if it gets worse, the ride is slightly stiffer, but i really don't mind, still takes the major bumps ok
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
DidiBob
Jan 4, 2016 12:41 PM
Robospinner
22
Sep 24, 2015 08:47 AM
CostcoFanAUS
Sep 18, 2015 06:05 AM
fallacy
Sep 4, 2015 10:15 AM
