Throttle body or not.
Old Oct 14, 2024 | 07:06 PM
sanramon98's Avatar
5th Gear
I have a 2001 CL Premium. Every so often the engine dies, and I have to wait for the engine to cool down and restart the motor. I have a OBD II code reader and not seeing any codes. My initial assessment points to the throttle body. The body has 3 sensors plugs on it. Is it one of the 3 sensors: if so which one?
Old Oct 15, 2024 | 11:51 AM
No telling what your issue is without some kind of DTC to give direction.
Search car-part.com locally for a cheap replacement throttle body with sensors, last time I looked there were like 12 pages for the CL-P.
Found a Service Bulletin that may come close to your issue, look it over and check to see if your car's VIN falls within the range listed.
Good Luck!
File Type: pdf
Old Oct 15, 2024 | 12:54 PM
sanramon98's Avatar
5th Gear
Thank you for the TSB. The TSB does describe my problem. The reason I thought it was the throttle body because I had a very similar problem with my 2006 Honda CRV. The fault codes I got from the CRV points to the throttle body. The TSB points to the range of 1A000001 to 1A012396. My car VIN ends in 1A024962. I did buy a rebuilt throttle body from eBay, but the throat of the rebuilt unit is slightly smaller. The OEM unit measured 2.70 inches and the rebuilt measured 2.60 inches. I tighten the clamp down all the way and the air leak is very apparent. There are 3 sensors on the throttle body. The bottom one measures the coolant temperature. Based on symptoms having the car cool down before restarting I was thinking it might be that.
Old Oct 15, 2024 | 04:16 PM
16410-P8E-A02 is the current throttle body part number for the CL-P, it replaces 16410-P8E-A01.
These TB's fit the vehicles below; therefore, it is possible you don't have an OEM replacement & they sent you something else?
It may be prudent to recheck the ebay listing for compatibility with the part number above.
Better yet, post a link to the ebay vendor you purchased it from, if possible.
The bottom sensor, #2 below, is the idle air control valve, the top one, #12, is the map sensor.
The red arrow points to the throttle position sensor which is incorporated into the TB assembly; however, a replacement can be found by searching the part number, IIRC'ly.
Throttle Body - 2001 Acura CL 2 Door PREM KA 5AT (acurapartswarehouse.com)
Old Nov 16, 2024 | 06:49 PM
Tosh's Avatar
Eurotrash
I had always thought any Honda hot start-up problem was always the PGM-FI relay (aka fuel pump relay) acting up. Pull out the relay and reflow the big solder joints, which crack over time...
Honda guy
1G RL (1996-2004)
Jul 7, 2024 06:39 PM
MiaQbn23
Jul 10, 2014 08:11 PM
types1967
Apr 16, 2003 05:14 AM
