For those with CAI......
Someday pigs WILL fly!
if you ever put the stock airbox back in, I have a tip for you. THe upper portion of the forward black hose goes up inside the large opening in the frame. WHen we took them out, we distorted the piece to make it pull out from the bottom. It will not go back in unless you either heat the piece or trim off about a 1/2 inch from the side that is next to the battery. Then, and only then, can you get it into the right position to put the bolts back in.
I found out the hard way.
