Thermoblok Spacer Disaster!!!
Old 09-28-2007 | 10:35 PM
NEVERSUMMER's Avatar
EVERYTHING IS FOR SALE!
Red face Thermoblok Spacer Disaster!!!
So I get the package, take everything apart. And the throttle body spacer holes do not even alighn, By like a half inch. Called and left message to outlaw engineering and e-mail awaiting some good news..... He better hook it up with one that fits regaurdless. But the lower intake manifold spacer fit. Ok
So Installing it all back on and now the car idel's up and down, also its running rich. What to do. Do I reset ECU and let idel for 3 minutes??? I was gonna do that but didnt.
Then snaped a bolt to the plenium right off. So now theres a whistle from the top of the plenium.
I did plug everything back in...
I did clean everything with throttle body cleaner...
Wheres is our mass airflow sensor? Is that the sensor next to the throttle body?
Old 09-28-2007 | 10:39 PM
typeR's Avatar
u got a type S or non
Old 09-28-2007 | 10:42 PM
Cls6
Old 09-28-2007 | 10:44 PM
typeR's Avatar
sounds like u may have got a non type S tb spacer ...btw wouldnt call that a disaster...im sure that if you ordered the right kit theyll send u the new tb spacer
Old 09-28-2007 | 10:48 PM
Well I say that cause it idels up and down like shit.
You know how I can fix that? I cleand the IACV.
Old 09-28-2007 | 11:56 PM
Accord_V6_400m's Avatar
4drs just wanna have fun!
fix the vacuum leak :p
Also, we don't have a MAF sensor, we run off the IAT and MAP sensor.
Old 09-29-2007 | 01:04 AM
CleanCL's Avatar
the bolt you snapped is causing a vacuum leak which is why your idle is doing that.
get in touch with outlaw, they will hook you up with what you need, their good guys.
Old 09-29-2007 | 06:49 PM
Allout's Avatar
Blown is Best
The studs and bolts do not get torqued very high. There should be no way to snap a bolt if you do it right. Check the specs and do not overtorque.
Old 09-30-2007 | 12:19 AM
Bobbydoedoe's Avatar
I'm Cool
yeap, and remember you are bolting that thing on a soft aluminum block
Old 09-30-2007 | 12:58 AM
Yeah but check engine light came on and I got it checked out and it said either oxyden sensor, random misfire, or injerctors.... And its jerking real bad now..... What do I do???
Old 09-30-2007 | 03:29 AM
The Dougler's Avatar
Unofficial Goat
why would you install it if that parts don't fit correctly?
Old 09-30-2007 | 04:40 AM
Lower intake manifold spacer fit. TB spacer did not. Reading the whole thread helps sometimes. Thanks for the input though.
07-16-2017 08:33 AM
CL-S progression 01
01-26-2016 05:15 PM
rockvilleTL
09-19-2015 05:44 PM
yvr_tsx
09-15-2015 02:14 PM
