Thermoblok installed...
Old Mar 6, 2005 | 06:47 PM
NiteQwill's Avatar
Adventurist.
Talking Thermoblok installed...
Relatively easy install. IMO, the hardest part was cleaning the old gasket material off and pulling the damn hoses.
Thanks to Edddie for the extra hand. I will post pictures in a short bit. Though the kit comes with instructions, a picture install is always helpful, so I'll post that up too.
I cleaned the TB while everything was apart. The response is so much better!
The butt dyno is definitely there, WOW. I'm very impressed and would highly recommend this cheap mod.
Old Mar 6, 2005 | 07:00 PM
phipark's Avatar
Not Asian
What did you use to clean the TB? That's not a bad idea since you have it taken apart, already.
Old Mar 6, 2005 | 07:04 PM
Edddie's Avatar
We used "Throttle Body Cleaner." You can get it at any auto store.
Old Mar 6, 2005 | 07:39 PM
ndawood's Avatar
Resident Troll.
How long did the install take you? Did you use all the materials that came with the kit or was there something that you were able to reuse?
Old Mar 6, 2005 | 07:45 PM
NiteQwill's Avatar
Adventurist.
About 2-2.5 hours. You use all the materials, there is nothing you reuse.
Old Mar 6, 2005 | 08:02 PM
phipark's Avatar
Not Asian
Old Mar 6, 2005 | 10:38 PM
darrinb's Avatar
///M POWER
guys with the blower cant use this right??
Old Mar 6, 2005 | 10:56 PM
mrsteve's Avatar
TB spacer,
Manifold spacer,
Old Mar 6, 2005 | 10:59 PM
mattg's Avatar
i'm going to find out for sure
Old Mar 6, 2005 | 11:04 PM
mrsteve's Avatar
How soon?
Old Mar 6, 2005 | 11:13 PM
mattg's Avatar
april at the latest
will i run out of fuel w/ s/c hbp + 50 shot?
Old Mar 6, 2005 | 11:20 PM
mrsteve's Avatar
E-manage is a must...
My A/F was between 11.0:1 and 12:0:1 on the dyno so plenty of fuel with just the HBP. Actually it didn't lean out to 12.0:1 until 7,000 rpm.
I'd think you'd need more fuel via 7th injector, e-manage, etc.
You going to spray direct port?
Old Mar 6, 2005 | 11:26 PM
mrsteve's Avatar
I'm wondering how things would hold up if I shot a small (35) shot directly into the IC at the track...
Old Mar 6, 2005 | 11:39 PM
Edddie's Avatar
Here is the DIY:
http://photos.phytte.com/view_album....okInstallation
Old Mar 6, 2005 | 11:41 PM
Edddie's Avatar
BTW, I pulled a OBD Code after the install on my test drive... P1399 (Random Cylinder Misfire/Ignition Control System); this was in 3rd gear around 5200RPM. The check engine light started blinking then went away.
I scanned and reset the code. No problems since.
Do you guys think it was an ECU adjustment problem?
Old Mar 6, 2005 | 11:42 PM
mattg's Avatar
you really want to spend another $500?
Edddie's Avatar
The above posts were by Dustin: NiteQwill
Old Mar 6, 2005 | 11:55 PM
mrsteve's Avatar
LOL at this point what's another $500?
I probably won't do it. But i'm curious to see if it would hold up.
I'm sure if I didn't swap the blower pulley it would hold up fine.
Old Mar 6, 2005 | 11:56 PM
mrsteve's Avatar
Old Mar 7, 2005 | 12:00 AM
typeR's Avatar
someone should also post how the engine cover will no longer fit but all that is nessecary is to modify the cut out for what i think is the TPS what ever connector that is on top of the TB...this will likely be my next mod
Old Mar 7, 2005 | 12:05 AM
Edddie's Avatar
Nope, the engien cover will not fit without a slight Dremel modification.
Old Mar 7, 2005 | 12:08 AM
mattg's Avatar
F the engine covers
i only run the front cover anyways.
Old Mar 7, 2005 | 01:23 AM
NiteQwill's Avatar
Adventurist.
Just did an "under the hood feel." Wow, the IM and TB are nearly cold to the touch with the engine warmed up and on. The combination of the JetHot, Mugen mods, and Thermoblok has seriously cut come underhood temps. My busy ass needs to get a dyno.
Old Mar 7, 2005 | 01:39 AM
Allout's Avatar
Blown is Best
Good to see another recommendation
When is the SC going in???
mattg's Avatar
soon, very soon.
Old Mar 7, 2005 | 01:57 AM
Allout's Avatar
Blown is Best
soon, very soon.
I would imagine before WCM4
Old Mar 7, 2005 | 02:00 AM
mattg's Avatar
long before
Old Mar 7, 2005 | 02:03 AM
Edddie's Avatar
Did you guys see the DIY? I was the hand model for most of the pictures.
Old Mar 7, 2005 | 02:08 AM
Allout's Avatar
Blown is Best
I was wondering who's hand that was. Figured Dustin brought in a professional hand model for this. I haven't seen a hand like that since George Costanza was at his peak.
Old Mar 7, 2005 | 02:10 AM
Allout's Avatar
Blown is Best
long before
I guess you'll have plenty of time to tune.
Old Mar 7, 2005 | 08:42 PM
Edddie's Avatar
That's exactly what I told him! I can also be bigger than that guy from Zoolander.
Old Mar 7, 2005 | 10:29 PM
typeR's Avatar
what was that a scholl for ants...it would have to be atleast....3 times bigger than this
Old Jan 16, 2008 | 07:26 PM
Silvaccordex01's Avatar
Hey those pix dont work anymore, can you repost? I know this thread is old but im getting my P2R plenums and would like to know how to take the IM off
CleanCL
Apr 12, 2007 09:26 PM
cadesigns02
Mar 9, 2007 11:02 AM
ghost_masterCL
Feb 5, 2006 03:11 AM
Eggplant-EX
Apr 23, 2002 12:26 AM
