Is there a way?........
I ♡ PEK PEK
to stop the parking lights from blinking when I unlock/lock my car with the remote?
I looked in the owner's manual and did a search but did not come up with anything. My old Maxima had this option, hopefully this car has it too.
Thanks in advance.
Thanks in advance.
I dont think so, unless you splice into the hid switching mechasism then they will only go on when the hids go on ( its a little more comlicated than that)
why dont you want they coming on ??
I ♡ PEK PEK
I hooked up the signal wire for the relay for my fog light's HID into the parking light. Now everytime I unlock/lock my car my ballasts fire up for a couple of seconds.
I'll just hook up a switch to it tomorrow.
Thanks everyone for the responses. My fogs are brighter than my headlights now, guess it's time for a retrofit.
I did the same thing LOL, thats what I thought you did
I ended up hooking mine up an ignition switch(relayed) , and a switch so when I turn my car on the hid fogs come on, and I can turn them off when I want
I also hooked hid high beems, so I have my fogs as DRLs
I didn't want this to happen or to remember to have to turn them off so I reran a the signal wire back to my low beams...much easier for me since I never run just the fogs alone.
I ♡ PEK PEK
I originally had the signal wire running off my low beams that the fogs turned on with my headlights. I had a hard time aiming them as my headlights overpowered my fogs.
When I installed HID's, I rewired them to my parking so I can just turn on my fogs by themselves to aim them. Since they're brighter than my headlights now, I really didn't have to re-wire them in the first place.
Why not run the fogs independently from everything else? Use 14awg wiring, directly to the battery. Wire in a switch too. If you wire it correctly they will turn off when the car is off.
I ♡ PEK PEK
Couldn't sleep last nite so I stayed up until 4 am re-wiring and aiming my fogs. All is well now, they are off when the car is off.
Quick question about aiming them though. At 25 ft they are 4 inches below my headlight's "cutoff" line, beyond that they go higher since they are pointing upward.
Is this okay? I would hate to think that I'm blinding other drivers.
^ i agree on both fronts.
this is why HID fogs aren't on my to do list anytime soon. lol
I wanna just get some LED super bright bulbs and put them in and call it a day.
But they are 80$ !!!! 18xs brighter though than a normal LED so I am still considering it.
I just want them to not LOOK yellowish when my lights are so nice and bright. and the LEDs would fix that up..
class23
Jun 14, 2007 01:45 PM
jwphones
Jul 24, 2006 04:02 PM
