Is there a safe spray lube for the CT rear swaybar bushings?
boosted is best
Is there a safe spray lube to use for CT rear swaybar bushings?
I've also got a squeaky CT rear swaybar. Is there any type of spray type lubricant that would be safe to use on the polyurethane bushings that would stop the squeaking for several weeks? The reason I ask, is I don't have the time remove, lube and reinstall the bushings, risking breaking a bushing bracket bolt. I'd prefer to just spray the bushings cause I'm due to bring in my CLS to the dealer early next month where they will replace the bushings with hard rubber bushings, along with installing konis/CT strutbar & catback exhaust.
boosted is best
Originally posted by agui
call comptech, order the NEW rubber bushings and rpl them urself. won't take u more than 20 minutes.
09-15-2015 06:44 PM
