Are There Alignment Problems With Shorter Springs
Old Oct 12, 2002 | 08:39 PM
Pappy's Avatar
Do it! U Only Live Once!
Are There Alignment Problems With Shorter Springs?
I was thinking of getting the CompTech springs for my S, but I'm starting to hear about alignment problems that occur more often than with the standard springs. Have any of you guys that put CompTech's springs on have that problem?
Old Oct 12, 2002 | 09:02 PM
JRock's Avatar
Old timer
It was pretty minor, but the inside edges of my rear tires did wear faster than they should have due to camber from the Comptech springs.
Old Oct 13, 2002 | 02:02 AM
CLSter's Avatar
Under the radar
Well
Is this a problem that can be fixed with a four wheel alignment or is it another "live-with-it" and shut-up kind of deal?
Maybe just getting the CT anti-sway bars will be enough.
Old Oct 13, 2002 | 04:08 AM
BigPimp's Avatar
I have Eibachs pro-kit and my alignment is within spec. If there is irregular tire, I dont notice, but I do rotate about every 7500 mi.
Old Oct 13, 2002 | 11:13 AM
CO-CL-S's Avatar
Re: Well
An alignment may be all that is needed, if not within specs, a camber kit may be required.. YMMV
Old Oct 13, 2002 | 11:23 AM
Mike's Avatar
I have the CTs. 3 of my 4 wheels have .5 degrees neg camber. 1 wheel has 1.0 degree neg camber. Next up is a camber kit.
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Zonian22
Nov 14, 2015 01:20 PM
Zonian22
Sep 2, 2015 08:19 AM
