from syntheic back to regular motor oil ?
I started using castrol syn oil because I had a s/c and thought the car would run better but now I have put my car back to stock with a cai and wanted to know if I can go back to using regular motor oil. will this hurt or effect my car or will I have to continue to use the syn oil. I dont see the benfit of syn oil and the price is to high because I change my oil every 2500 miles and with the syn oil it cost me like $30 with filter vs. $12 with filter for the regular oil.
Re: from syntheic back to regular motor oil ?
Why are you changing every 2500 if you're using syn? There's no sense to that.
BTW, castrol syn. is probably the worst synthetics. You should go with Mobil 1.
I also feel that synthetics are waste of money unless you plan to drive your car beyond 100K miles. If you plan to sell it before 100K miles - I would not waste my money.
There are basic oil analyzer kits out there that will prove to yourself you can use Mobil1 or Amsoil for well over 10k miles with a good filter changed at 5k miles. At 10k miles my analyzed results are very close to brand new petro oil.... If you change at 2.5k yes it would be expensive. But at 10k changes I spend $52.50. You spend $60. There are other benifits to using a PAO based oil (SYN) like heat removal on bearing surfaces and less friction. Some engines after 200k miles show very little wear. BUT I agree with "Comrad" above if you plan to sell before 100k let the next owner worry about his used car. Some of us just want the BEST science has to offer.
see here,, Castrol specs aren't the better of true Syn oils...
http://www.unofficialbmw.com/all/misc/all_oilfaq.html
However, even if you are planning to sell your car before 100K it might be a good idea to use synehtics and change it offten. If you get car enthusiast buyer, he will greatly appreciate all the receits for synthetic oil and good filter... but otherwise it does not matter... especially if you trade in your car at the dealer... they don't give a sh*t....
Gimmie my points Biatch!
[QUOTE]Originally posted by russianDude
[B]The only reason I am using synthetics is because I plan to drive it till 200K miles ( transmission will be dead before the engine )
Hey maybe you can extend the trans life also,, I use
this (see site below), I have 56k on orginal trans and just switched to syn trans oil. BUT if my trans is going to go I hope it's before 100k.
http://www.amsoil.com/products/atf.html
Lead Footed
If you consider your car a daily beater and don't care about max performance and life if the engine (plugs, valves, etc) sure you can switch back.
On the other hand, if you are a gearhead and love max performance and such . . . why? Just cut back on the frequency of your oil changes. 7,500 to 10k is sufficient for most driving conditions. You can change your filter every 5k and add a little oil and do a complete change at 10k even.
Based on your frequency I would guess that you run your car hard and even race it at the track. That or towing would be some of the reasons to want to change it that soon.
Shoot, that's cheap compared to what I pay and I change mine 2x a year, and sometimes before a race meet.
Ruf
NEO 5w-30 $10qt that includes T&SH
Ruf
well personally if youre already synth id stay synth.
regular oil will build up mineral deposits in your engine as time passes.
id switch to synth in my car but its got 125k miles and its used regular oil this whole time, that if i go synth ill make all the mineral deposits break loose and gunk my engine up.. and possibly open any seal leaks that the mineral deposits were clogging up.
Hmmm... I've got 77k on my '01 CL-S, and have used regular oil the whole time. What's the group concensus regarding my situation for switching? Not to off-topic this thread or anything...
I change my oil every 2500 miles because I like to do it, I go over to my friends house and we just hang out and talk about car while we change the oil. I think the car feels smoother to me after I change the oil< I even think the car feels smooth after I wassh the car as, LOL Its just the way I think
another ?
If castrol isnt good what would be the best brand for the money,
nothing outrageouse like $15 a qt
Look at the spec sheet for 5w30,,, mobil1 and amsoil are at the top of the list... I use Amsoil because they market /research and sell the oil as a extended drain interval,,, Redline is also good but I havn't seen test results from extended drain intervals. Mobil1 has 40 years supply of petro oil in the ground so they need people to keep changing oil every 3k.
My car is always a good 5mph faster and much smoother after a good wash.
Find beauty in dissonance
My analysis showed 3X more wear compared to AMSOIL (in my car FWIW). And the Mobil1 was in BAD shape at 7500 miles with a new filter and 1/2 quart oil done at 3750.
Originally posted by Bluto
I can't believe you of all people recommend Mobil1.
I have seen this brand called royal purple , are they any good
I'v not seen any test data... go to www.amsoil.com They have a dealer locator or just order on line and have it delivered
Originally posted by fusionnv
I heard from lots of people amsoil is nice and works well, the only problem is that it is a pain in the ass to fine if like one day u want to go change ur oil. It not normally carried in large chain stores or automotive shops.
IIDXholic
10-08-2015 07:53 AM
