Sway bar install questions...
Old Mar 25, 2002 | 01:26 PM
JasonT's Avatar
OK a few questions that are not covered in the faq's.
1-What kind of lube should be used?
2-Should I use the supplied teflon tape?
3-Where should this tape be used?
4-Where should the lube be used?
5-In the kit I get these black clips to place on each side of the bushings, do I need these?
6-The instructions indicate I need to clean the area where these clips go from any lube, is this the case?
marcelft
Jul 10, 2018 06:17 PM
Onyxthecat
Oct 18, 2016 02:05 PM
drone619
Jan 26, 2016 07:09 PM
MonkeyTrucker
Sep 21, 2015 06:15 PM
k6biv
Sep 10, 2015 06:37 PM
