Suspension help needed...
Old Feb 23, 2003 | 06:47 PM
SlyTLS's Avatar
Bada Bing
I've got a problem and need some advice...
I am currently running the Ground Control coilovers with the Koni Yellow adjustable shocks...my problem is that with the stereo setup I have in the trunk the rear end keeps bottoming out (the shock mount keeps hitting the rubber stopper causing a loud clunk). I have the Koni's set at their hardest setting and it still happens. Does anyone here run the same setup? Have you ever had this problem and if so did you overcome it and how?
Any and all suggestions/help is appreciated!
Sly
Old Feb 23, 2003 | 11:58 PM
SlyTLS's Avatar
Bada Bing
<bump>
Old Feb 24, 2003 | 12:48 AM
DtEW's Avatar
The first and most obvious thing to try is to raise your spring perches. You may lose the look that you want, but at least you won't be bottoming.
The real solution is to talk to Ground Control about higher spring rates. Then you have to pray that your Koni's have the damping range to accomidate the higher rates. If not, the Koni's can be revalved by a Koni service facility for the higher rates.
Old Feb 24, 2003 | 01:11 AM
4pumpedCL's Avatar
Honkey
cut down your bumpstop. Mine was about 1/4" thick when I had springs and shocks.
-Aaron
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
