Suspension creaking and squeaking over bumps
I hate the Mets
Like the thread suggests, whenever I go over the tiniest bump (especially the rear of the car) I get this creaking sound that makes my car sound like it is an 80 year old wooden door with rusted hinges...
Now, my car is lowered on stock struts ...Could that be causeing the problem? The car rides the same as it always has - but Im at a loss....Perhaps its the sways
Anyone else have this problem...I tried searching but I had no luck and after 4 months of this creaking its time to nip it in the bud.
Where is my super sauce?
I was thinking of re-lubing and checking torques on the sways during my next maintenance session.
What specific type of lubricant/grease do you guys use?
Audi S4 driver
Sounds like the sways.
The first time I did mine I wrapped the rear bar itself with two layers of teflon tape at the two points in which it contacts the bushing, then I took regular automotive grease and greased the inside of the polyeurethane bushing. No squeaks and they were installed last January (10 months).
EDIT: does anyone know the torque specs on the rear sway bar bushing bolts?
Doin' da crack shuffle
Lithium Grease.
Blader,
what size are the bolts? I'm sure there is a standard torque for bolts. You just need the diameter and the grade of the bolt (stamped on top of the bolt head).
http://www.dodgeram.org/tech/specs/bolts/M_bolts.html
Not Asian
I'm not so sure it's the sways. I installed my sways in July or so. I wrapped them in teflon tape and used the lithium grease. A little too early to do it. But it only happens when I back out of my driveway over the curb. It's not that bad though. Just need to turn the stereo first.
Audi S4 driver
phipark .. when do you think the sways move?
Sways take away some of the independence of the suspension. I'm sure you noticed that when you put the sways on and hit a few bumps, the car felt a little stiffer. The sways limit how much the two sides of the suspension can move independently from one another. So when backing out of the driveway, if one wheel goes over a curb or goes over the curb at a different time than the other wheel, its putting stress on the bar. which in turn puts stress on the bushings. hence the squeak.
Got a Job!
how the hell do you check the torque of the bolts? I don't know jackshit about tools or what not...when I last put the lithium grease on, I just re-tightened em w/ a hand socket wrench until they were really tight. Oh and btw, my sways sound awful, and after 3 weeks of greasing em, the HORRIBLE creaking & bullshit sounds comeback. How do I know if theres anything wrong w/ em?
MrHeeltoe
20
02-23-2023 01:54 PM
lanechanger
10-13-2015 10:56 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
