Suspension
Old Jul 14, 2003 | 03:03 AM
MethodRN's Avatar
HELLLLLLOOOOOO NURSE!!!!!
Suspension
Alright guys set me straight....
What is the difference between Koni Yellows and Neuspeed/Koni Yellows? I went to AutoCarParts.com and they sell both. The latter being more expensive. Is there a big difference in ride quality or just adjustability. I reason I ask is cause on TornActive.com I can get the Neuspeed/Koni set for the same price as the Koni Yellow sent on ACP. Please set me straight as to which ones yall use and recommend. Thanks
Old Jul 14, 2003 | 03:43 AM
civic4982's Avatar
SHIFT_over.so.I.can.see
http://www.neuspeed.com/products/pro...ils.asp?app=35|C4&type=2&ltype=ns_import&p_id=1131
Look at the description. The regular Konis have 3 grooves for ride height adjustment and the Neuspeed ones have 5 grooves. i.e. more adjustable.
Old Jul 14, 2003 | 06:49 AM
brian6speed's Avatar
Lone Wolf
It also has a 20 mm shorter shaft
Old Jul 14, 2003 | 11:27 PM
MethodRN's Avatar
Thanks guys. Now I know you can't lower our car too much lower than what the Comptech springs give you without using camber correction, so is it worth getting the Neuspeed Koni's? Also does the shorter shaft cause more bottoming out or affect ride quality? Lastly, what do I need to know in terms of torque spec's or tips when installing springs and shocks on the CL? Thanks again
Old Jul 15, 2003 | 12:57 PM
gsrblack's Avatar
Yeah, if you go with the Comptech springs, which shocks are more fit for them...the Koni yellows or the Neuspeed Koni's?
Old Jul 15, 2003 | 05:27 PM
CLSter's Avatar
Under the radar
I am thinking of getting the Nuespeed Konis with my stock springs. I only want to lower the car an inch or so.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
