Supercharging the CL-S 6spd - Final HP(estimate)
Supercharging the the CL-S 6spd - Final HP
Thanks for the pictures from the Comptech source. This pretty much confirms what their R&D department has been saying. This thing will hit the streets in December!!!
The compression on the Type-S motors are a hefty 10.5:1. I strongly doubt Comptech will up the boost to anything over 6psi. My turbo prelude (10.0:1 compression) started having blow-by 6 months of boosting 8psi. Then again, I did overboost a few times... but the supercharger can never boost higher than the regulated amount without physically changing the pulley diameter.
It looks like Comptech will be suppying the following the blower, intake-plumbing, ice-box gadget, fuel regulator (boost-dependant) etc.
I am curious as to how they are going to do the engine management. The MAP (Manifold Air Pressure) sensor on Hondas/Acuras does not like boost. The dirty way to fix this is to move the MAP sensor via a hose from the plenum and put a bunch of one-way valves. The elegant way to fix the problem is to do it electronically - which I am sure Comptech will. GM provides a MAP sensor that works with positive manifold pressure (used on the old GN's). Another question will be ignition-timing. Is there some work to the ECU to mange boost-dependant retard on the timing. I trust Comptech will be concentrating on these last two items to maximize the gains from the S/C prior to releasing it. Since these S/C's will be available through Acura dealers (including installation) I am sure Comptech will be extra-cautious as usual so as to not have a plethora of blown CL-S's arrivng for warranty repairs (of course with the supercharger removed!! :-))
I estimate the final # to be 345 front-wheel hp. This translates to a hefty 400hp at the crank - right there with the M5, 911 turbo, C5 Z06 and Ferrari Modena.
Street tires.... 13.3 in the 1/4. This car requires you to launch ridiculously low (~2300 rpm) to get a sub-6s 0-60, so forget any type of launch with the S/C. Slicks... and a good clutch... we are seeing mid 12's baby!!!!
I want to hear what the predictions from the other folks on this board are.
To fix the MAP problem heres what you'll use:
E.S.M. (Electronic Signal Modifier)
$149.00
NEW!
This adjustable switch is commonly
used to keep the ECU from seeing a boost
signal from the MAP Sensor when you are adding
a turbo or supercharger to a car that didn't come that way.
Can be used on any car or sensor up to 3.4 volts.
Easy4 wire hookup. Comes adjusted for Honda/Acura
MAP voltage signal, but is easily adjusted to
needs of other cars. Universal fit.
Not subject to CARB certification.
$149.00
NEW!
Duck Fuke!
Re: Supercharging the the CL-S 6spd - Final HP
i think your hp figures seem a bit optimistic
Sold 12/29/04 :-(
Well Said.
$149.00
NEW!
$149.00
NEW!
Yea that would be sweet. Acura plans on revising their '04 CLSs so hows about haveing the '04 CLP, CLS, and "CLS-SC" . For an additional 4K + $30K for the CLS u get a warrantied, preinstalled CT SC.
But what is CT doing to allow the 6MT put all that power to the wheels. I mean where is that high performance clutch?
Juker008
Juker008
If used correctly you can run higher boost. Maxima guys run 10-12psi now without problems. They have 10:0:1 compression as well on the VQ.
Re: Re: Supercharging the the CL-S 6spd - Final HP
I'm assuming that those Maximas have intercoolers to cool all that additional air. I would be hard for me to think that a Maxi could handle 10-12 PSI with just a better fuel system.
Juker008
Re: Re: Re: Supercharging the the CL-S 6spd - Final HP
Juker008
Juker008
Originally posted by scalbert
But for maybe only one or two passes when the clutch finally goes south...
Smitty
How about ignition timing?
Thanks for the clarification on that... I just referred to the MAP sensor/ECU as a single entity. Although the stock MAP sensor cannot read much over a couple psi of positive manifold pressure.. maybe 1/2 a bar at most - the ECU is a different story.
A lot of high-boost cars (20 psi, 30 psi, whatever) run the GN map sensor which works upto 2-3 bar. I think HKS, Greddy might have their own versions.
One last concern of mine is ignition timing on this supercharger setup. Provisions for fuel are adequate (for 5.5 psi, the upgraded fuel-pump and regulator work fine) and the ESM takes care of the ECU. Does Comptech rely on the factory knock-sensor to retard timing? This car, along with the NSX uses direct ignition... so its not a trivial (most the distributor a notch or two) to do the timing. On the NSX, there's a trick where the ignition timing can be adjusted (retarded or advanced) quite easily - the trick is drilling through some plastic and a metal plate to find the igntion control module's adjustment point. I am not aware of the CL-S having this.
Any clues?
Any clues?
Re: How about ignition timing?
That might be a bit optimistic, IMO. With a standard motor and other basic mods it should be in the 310 - 320 range. But with a worked motor, lower CR with more boost, etc. 345 - 350 could be achevied.
Juker008
Joe Avesyan
09-29-2015 03:57 PM
2001, acura, boost, cl, cls, comptech, electronic, map, maximizing, modifieracurazine, pressures, regulator, sensor, signal, supercharger
