Supercharger tips
Old Nov 26, 2003 | 11:35 AM
Chemmech's Avatar
Supercharger tips
1. You whp will be severly affected if the automatic transmission fluid is low. I just did the trans. cooler upgrade and was down by a quart of fluid. Car was "slow like turtle," for a couple of days.
2. Excess noise from the a/c belt engine pulley can be erradicated by spraying down the spring inside the idler with aerosol penetrating fluid. I used two straws inserted into eachother to help in directing the fluid to the gap between the pulley(between the tensioner arm and tensioner base). Don't get the lub. on the belt.
Happy motoring.
Old Nov 26, 2003 | 03:46 PM
ModAddict's Avatar
My trans was overfilled from the factory,... the cooler brought it down right to the mark. I keep checking it and it's all good.
I'll try the lube and see if I notice anything.
Old Nov 26, 2003 | 06:33 PM
Chemmech's Avatar
Be sure you check the fluid with the engine off.
Old Nov 26, 2003 | 07:15 PM
proaudio22's Avatar
-S namyaC-
Actually I think you are supposed to check with the engine on and warm (IE idle for 10 mins), otherwise level will always appear wrong - at least that's what the manual to my last car said. Maybe acks are diff?
Old Nov 26, 2003 | 08:27 PM
Chemmech's Avatar
I'll double check the manual. Let's see, my manual says shut off engine, nothing about checking it with the engine on. Having been just a quart low was enough to dramatically degrade the acceleration of my car. I guess my car is very picky. When I installed the cooler I put the lines into a couple of empty coke cans to determine flow, guess I lost alot of fluid plus whatever the cooler required.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
ivan06106
Sep 26, 2015 04:38 PM
