Supercharger tips
Old 11-26-2003 | 12:35 PM
Chemmech's Avatar
Supercharger tips
1. You whp will be severly affected if the automatic transmission fluid is low. I just did the trans. cooler upgrade and was down by a quart of fluid. Car was "slow like turtle," for a couple of days.
2. Excess noise from the a/c belt engine pulley can be erradicated by spraying down the spring inside the idler with aerosol penetrating fluid. I used two straws inserted into eachother to help in directing the fluid to the gap between the pulley(between the tensioner arm and tensioner base). Don't get the lub. on the belt.
Happy motoring.
Old 11-26-2003 | 04:46 PM
ModAddict's Avatar
My trans was overfilled from the factory,... the cooler brought it down right to the mark. I keep checking it and it's all good.
I'll try the lube and see if I notice anything.
Old 11-26-2003 | 07:33 PM
Chemmech's Avatar
Be sure you check the fluid with the engine off.
Old 11-26-2003 | 08:15 PM
proaudio22's Avatar
-S namyaC-
Actually I think you are supposed to check with the engine on and warm (IE idle for 10 mins), otherwise level will always appear wrong - at least that's what the manual to my last car said. Maybe acks are diff?
Old 11-26-2003 | 09:27 PM
Chemmech's Avatar
I'll double check the manual. Let's see, my manual says shut off engine, nothing about checking it with the engine on. Having been just a quart low was enough to dramatically degrade the acceleration of my car. I guess my car is very picky. When I installed the cooler I put the lines into a couple of empty coke cans to determine flow, guess I lost alot of fluid plus whatever the cooler required.
07-16-2017 08:33 AM
08_UA7_Gr33k
02-11-2016 03:17 PM
Joe Avesyan
09-29-2015 04:57 PM
08_UA7_Gr33k
09-27-2015 02:56 PM
ivan06106
09-26-2015 05:38 PM
